No crank issue - Page 2
Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 46
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, No crank issue in Past Cadillac Vehicle Discussion; OUCH! You may well have fried the PCM (and maybe some other components). You NEVER EVER do that. Why in ...
  1. #16
    68
    82,064
    Re: No crank issue
    OUCH! You may well have fried the PCM (and maybe some other components). You NEVER EVER do that. Why in the world did you do that?
  2. #17
    wdavidson09 is offline Cadillac Owners Member
    Automobile(s): 2003 Cadillac Deville
    Nov 2013
    25
    22
    Re: No crank issue
    Would a PCM out of a 1998 Deville work in a 2003?
    I did read on this forum that it can sometimes resolve the issue.
  3. #18
    reppinshadyvill is offline Cadillac Owners Fanatic
    Automobile(s): 2003 DTS
    Nov 2012
    Central FL
    34
    205
    Re: No crank issue
    Hopefully he meant he touched the - and + cables together. Hopefully he didn't connect the - cable to the + terminal on the battery.
    Even with a dead PCM shouldn't the car still do something when you turn the key to the on position?
  5. #19
    Nov 2013
    25
    22
    Re: No crank issue
    Both removed from the battery. The car still turns but just doesnt turn over. I did only touch the cables together. I didnt touch the negative cable to the positive while it was still connected.
  6. #20
    Nov 2012
    Central FL
    34
    205
    Re: No crank issue
    Well then your PCM, theoretically, should still be ok. When you turn your key to the on postition, does the car acts as it normally should? Is it just not doing anything when you go all the way to the start position?
  7. #21
    Nov 2013
    25
    22
    Re: No crank issue
    It doesnt crank. When you look at the PRNDL on the dash it does not have an indicator such as a box indicating which gear it is in.
  8. #22
    Nov 2012
    Central FL
    34
    205
    Re: No crank issue
    Check ALL of your fuses, fusible links, and negative grounding cables in the engine compartment.
  9. #23
    Nov 2013
    25
    22
    Re: No crank issue
    I have checked all of the fuses and links. But have you guys heard of the indicator disappearing and the fuel gauge not displaying anything?
  10. #24
    68
    82,064
    Re: No crank issue
    Quote Originally Posted by wdavidson09 View Post
    OK, in that case you didn't harm a thing.
  11. #25
    Nov 2013
    25
    22
    Re: No crank issue
    I didnt think that i did. Went through and checked all of the fuses again still good. Stumped.
  12. #26
    68
    82,064
    Re: No crank issue
    So you turn the key and get nothing? No crank, no click. Do you have power anywhere else?
    Have you tested the battery with a DVM or had it tested or swapped it out with a known good battery?
  13. #27
    Nov 2013
    25
    22
    Re: No crank issue
    Yup installed a brand new battery yesterday. When i turn the key i can hear the starter relay in the PDC under the rear seat click but thats it. No trying to crank clicking like you would hear from the starter if your battery was dead, I mean nothing.
    Oh and i have power everywhere else.
  14. #28
    68
    82,064
    Re: No crank issue
    Well, at least you know you have power to the relay. Just for the hell of it, run a redundant ground. Use one of your jumper cables and run it from the engine to a good body ground somewhere.
  15. #29
    Nov 2013
    25
    22
    Re: No crank issue
    Nope still nothing.
  16. #30
    68
    82,064
    Re: No crank issue
    Maybe a bad starter or solenoid or connection at the solenoid. Might be time to have a look.
  17. Remove Advertisements
