96 Deville now throwing a P0171 and P0174 Codes.
Results 1 to 10 of 10
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 96 Deville now throwing a P0171 and P0174 Codes. in Past Cadillac Vehicle Discussion; Hello Forum Friends. I posted before about my 1996 Deville Northstar 4.6. Replaced the Fuel Pressure Regulator and now its ...
    ralphieboy57 is offline Cadillac Owners Member
    Automobile(s): 1996 DeVille
    Dec 2011
    Fountain Valley, Ca
    17
    Hello Forum Friends. I posted before about my 1996 Deville Northstar 4.6. Replaced the Fuel Pressure Regulator and now its throwing a P0171 (Fuel Trim System Lean,Bank 1) and a P0174 (Fuel Trim System Lean,Bank 1) codes. I looked through the Forum and found that its probably a cracked Throttle Body Plenum thus causing a vacuum leak. But I just read that the 1996 Northstar 4.6 motor dosn't apply to this. Ive checked the vacuum hoses and intake manifold but no leaks that I can detect. Were would be the best place to start troubleshooting? Is there a step process I should follow?
    I love my Deville but need it to pass smog so I can get my registration straightened out. So far Ive replaced the plugs and plug wires, air cleaner, fuel pressure regulator, and cleaned the throttle body out, oh and new front motor mounts. Any help would be greatly appreciated.
    68
    82,045
    Re: 96 Deville now throwing a P0171 and P0174 Codes.
    WOW! I could read that without my cheaters.
    Have you checked the manifold over pressurization valve in the tunnel behind the P/S pump? If it is not seated or the seal is damaged it will cause a vacuum leak.
    Dec 2011
    Fountain Valley, Ca
    17
    No I Havent. I will go check it now.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,179
    You'll need to listen carefully with a mechanic's stethoscope to find the vacuum leak(s). If it is the overpressure valve, the intake manifold must be removed.
    http://lmgtfy.com/?q=cadillac+forums...ld+removal&l=1
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    Feb 2004
    Minnesota
    65
    15,461
    you have a big vacuum leak somewhere -
    get a can of carb cleaner - attach the straw -
    spray it around all intake gaskets and hoses -
    when the idle speed increases - you found a leak -
    Dec 2011
    Fountain Valley, Ca
    17
    Just letting you guy know you were right..... Its the Backfire Valve in the intake manifold. Big leak!. I have the intake out but where did you purchase the part at. Autozone and Pep Boys don't have it listed. And how much did it cost yah. Thanks
    Feb 2006
    56,179
    Talk to Chris in Parts at Rippy Cadillac over there >>> tomorrow morning, business hours, EST (Wilmington, NC)
    Meanwhile look at your car, year model, engine, system in www.gmpartsgiant.com . Once you get to the correct parts text page you can click on the More Info tab to open a diagram keyed to the text page.
    Also - take a long, hard look at that PCV dirty air line - those rubber elbows rot out and crack with great regularity. Better safe than sorry. The Help! racks at large parts stores. If the plastic formed line is cracked, you can replace it with a proper length of reinforced fuel hose.
    jnpettit is offline Cadillac Owners Member
    Automobile(s): 1996 Deville
    Jan 2015
    Newnan, GA
    4
    I have the same codes on my 96 DeVille Northstar. First a rough idle, then the codes about 5 miles later. No obvious vacuum leaks revealed with the carb cleaner spray. Thought it might be bad fuel, so I replaced the fuel filter and filled up with Chevron premium. No change. However my parking brake has not been disengaging recently. Could there be a vacuum leak at the parking brake release actuator significant enough to make the engine run lean and trip these codes? Seems unlikely..
    68
    82,045
    Quote Originally Posted by jnpettit View Post
    Quite possible.
    rodnok01's Avatar
    Feb 2012
    NC
    6,649
    More than likely a bad vac line under the hood. Check behind pass strut tower. There are 2 lines that rot out.
  13. Remove Advertisements
