Water under car
Results 1 to 10 of 10
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Water under car in Past Cadillac Vehicle Discussion; Been noticing water spot under my deville.. Coolant level is full drove 4 hours yesterday engine temp was 190 whole ...
    Italia deville's Avatar
    Italia deville is offline Cadillac Owners Fanatic
    Automobile(s): 1998 deville
    Feb 2013
    Myrtle beach
    28
    160
    Water under car
    Been noticing water spot under my deville.. Coolant level is full drove 4 hours yesterday engine temp was 190 whole time coolant level still full
    68
    81,928
    Re: Water under car
    Is it just behind and inboard of the RF wheel? If so and you are using the A/C (as I suspect you would be in Myrtle Beach) it's A/C condensate. Dip your finger in it. Look, smell and taste like water? If so, that's what it is.
    Feb 2013
    Myrtle beach
    28
    160
    Re: Water under car
    Actually I have not used ac in while it dosnt work right that's why I knew it wasn't that
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,919
    Re: Water under car
    OK - Where is the "water spot" ? Under the engine is most likely a coolant leak. Under the passenger seat or trunk, most likely a normal exhaust system vapor weep - the resonator and mufflers DO have drain holes and this is a prime time of year for cool weather exhaust vapor.
    So the HVAC is set to ECON ? (A/C compressor will not run in ECON) - or does your car have an "A/C OFF" button ?
    68
    81,928
    Re: Water under car
    He has the ECON button, no A/C OFF button on the pre-2000 Devilles.
    Feb 2013
    Myrtle beach
    28
    160
    Re: Water under car
    Yea spot is right under front left mostly my coolant level has not changed and I have noticed little bit a water like to the touch it is watery
    68
    81,928
    Re: Water under car
    Maybe the drain is clogged an leaking rain water?
    bigm57ict's Avatar
    bigm57ict is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Coupe deVille, 1995 Sedan DeVille (sold)
    Aug 2011
    Wichita Kansas
    44
    1,845
    Re: Water under car
    I would double check the cooling system with a pressure test.
    Feb 2013
    Myrtle beach
    28
    160
    Re: Water under car
    Now the water is under middle of engine on ground
    68
    81,928
    Re: Water under car
    If it's just water, don't worry about it.
  13. Remove Advertisements
