95 Sedan Deville no sound to start - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 95 Sedan Deville no sound to start in Past Cadillac Vehicle Discussion; Is the starter motor visible on 4.9s? If it is, try whacking it a few times with a hammer (not ...
  1. #16
    DJSG3 is offline Cadillac Owners Fanatic
    Automobile(s): '03 Deville DTS
    Dec 2005
    Joisey
    254
    Re: 95 Sedan Deville no sound to start
    Is the starter motor visible on 4.9s? If it is, try whacking it a few times with a hammer (not too hard but not too soft) and then try to crank the engine. If it starts you need a new starter motor.
  2. #17
    69
    82,405
    Quote Originally Posted by LacVille95 View Post
    Finally got my battery to autozone today and the guy said it was 50% charged and since my battery is only a yr old he believes something may be draining my battery. Tomorrow I will be reinstalling it to see if the charge will start my car. If that is the case what could be draining my battery? They said I'd have to get my alternator/starter checked to see if that is the problem.
    Put a 12v lest lamp in line between the negative cable and the battery terminal. If the lamp illuminates, you have a draw. Start pulling fuses until it goes out. That will tell you what circuit or component is the problem.
  3. #18
    CaddyGas's Avatar
    CaddyGas is offline Cadillac Owners Fanatic
    Jun 2012
    454
    If you do have a bad starter or connection(sometimes a bad starter won't make a sound, I had one make a air sound) cranking it will also kill it, but check for a draw as Ranger suggested.
  5. #19
    LacVille95 is offline Cadillac Owners Member
    Automobile(s): Sedan Deville
    Jul 2011
    27
    29
    Thank you guys for all your suggestions.. I had a mechanic come out and he replaced my starter and it worked, I'm just glad it wasn't anything major. But now my heater hose connector broke off and is stuck in one of the heater hoses but that should be a quick fix..
  6. Remove Advertisements
