Results 1 to 14 of 14
Thread: HID lights - 2003 Deville
    Misdealville's Avatar
    Misdealville is offline Cadillac Owners Member
    Automobile(s): 2003 Cadillac Deville
    Aug 2013
    Chattanooga,Tennessee
    14
    Is there some kind of electrical issue with 2k3 Cadillac Deville when it comes to HID lights?
    69
    82,273
    Re: HID lights - 2003 Deville
    Not sure what do you mean.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    There is an issue with all Devilles when it comes to HIDs - they don't have projector headlights. Installing HIDs will cause glare for other drivers, put less usable light on the road, and is illegal.
    IIRC, last gen Devilles use the low beams as DRLs. HIDs can't run on half voltage. DRLs have to be disabled, or some rewiring has to be done.
    Unless you want to do a projector conversion, look into PIAA Intense White or Xtreme White bulbs.
  5. #4
    69
    82,273
    I thought the DRL's where high beam at half power.
  6. #5
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    Feb 2004
    Minnesota
    65
    15,690
    on Sevilles - YES -
    but for some DUMB reason - the Deville uses the low beam at half power -
  7. #6
    69
    82,273
    Why is that a dumb reason?
  8. #7
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,690
    if for no other reason -
    it causes additional wear and tear on the well-used low beams -
    compared to using the seldom-used high beams -
  9. #8
    DSNCB919 is offline Cadillac Owners Enthusiast
    Automobile(s): 1990 Cadillac Seville 2003 Cadillac DTS 2010 DTS Platinum
    Jun 2009
    North Carolina
    28
    538
    I have HID 8k on my Low Beams and my FOGS on my 03 DTS typically they work fine I think the DRL feature slightly shortens the bulbs life but Other than that its a GREAT
    addition. MoistCabbage is right when he says it will cause glare at other drivers but I only get people flashing high beams at me on country roads. People know its you from the other side of the highway ( which is kind of cool when you get a text from someone going other way on I-40. If you cant install it yourself make sure you trust and know whatever aftermarket company you get this installed by, the Ballast and harness can be crowding if not setup neatly, Also if you ever get sick of the HIDs you can
    bypass
    the HID ballast and connect your normal halogens. With the ease of getting into the Headlights of the 00-05 Devilles might as well try it.
  10. #9
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,690
    Quote Originally Posted by DSNCB919 View Post
    bypass
    REALLY?
    so - you KNOW you are blinding on-coming traffic with your blue-bling lights -
    and obviously don't give a damn -
    but you also text while driving - YA - REAL COOL -
  11. #10
    69
    82,273
    Exactly what I was thinking.
  12. #11
    Jun 2009
    North Carolina
    28
    538
    Only blinding on back roads , and its not near as strong as those trucks with hids
  13. #12
    Sep 2010
    East Boston MA.
    29
    26,323
    There are 2 last gen Devilles with HIDs in my city. I'm less than 5 minutes from Boston. NO back roads here. .....It's blinding enough to be distracting, annoying, and dangerous.
  14. #13
    Aug 2013
    14
    Why does the DRLs interfere with the low beam bulbs? How do I disable the DRLs
  15. #14
    Sep 2007
    Wilmington, NC
    13,969
    the low beam bulb is also the drl bulb
    posts #4 -> #7 kind of explain this and why
  • You may not post replies
