96 Deville 4.6L dies sporadically only at idle
Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By thrasherjen
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 96 Deville 4.6L dies sporadically only at idle in Past Cadillac Vehicle Discussion; Car has good idle, no codes set in PCM, but it will die sporadically only during idle. I could be ...
    thrasherjen is offline Cadillac Owners Member
    Automobile(s): 1996 Deville
    Oct 2013
    34
    Car has good idle, no codes set in PCM, but it will die sporadically only during idle. I could be driving the car and stop at a stop sign and then it will die, it will fire back up with no hesitation. I can also let it sit and run and it will eventually just shut off. Doesn't act like it is running out of gas and it starts right back up. I have tried the PCM, ignition module and the crank sensor. If anyone out there has any ideas, please let me know!!!
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,266
    Re: 96 Deville 4.6L dies sporadically only at idle
    clean the throttle body and Idle Air Contro0l valve
    68
    81,761
    I'll second that. Also pull the DTC's. Post them AND their definitions.
    Oct 2013
    34
    Ok, the PCM was not setting any DTC's. I cleaned the IAC and the EGR, same problem. Did a little more research and found that there was a second Crank Sensor (which I originally thought it was the problem), swapped that one out and it has been good ever since, I think I may have solved the problem. Thanks for all your help!!!
    LoveMyLac likes this.
  7. Remove Advertisements
