2000 dts. Transmission swap
Results 1 to 4 of 4
Like Tree2Likes
  • 1 Post By Submariner409
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 2000 dts. Transmission swap in Past Cadillac Vehicle Discussion; Im looking at an 2001 sts and 2001 dts to replace the transmission on my 2000 deville dts all are ...
    jbking2k2 is offline Cadillac Owners Member
    Automobile(s): 2000 DTS
    Oct 2012
    broward/miami
    22
    Im looking at an 2001 sts and 2001 dts to replace the transmission on my 2000 deville dts all are 9 vin . Question is are they interchange able ?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,847
    Re: 2000 dts. Transmission swap
    Should all be the same transmission unit in the 2000 - 2004 series of VIN 9 cars.
    jbking2k2 likes this.
    Oct 2012
    broward/miami
    22
    Really up 2004 , i was under the impression the gear ratio was changed after the 2001 .. Thanks for the reply
    Feb 2006
    55,847
    The VIN Y is a 3.11:1 cruise/economy ratio. VIN 9 is a 3.71:1 "performance " ratio - so for a given vehicle speed the VIN 9 engine is always at a higher rpm - further up in the power curve.
    This table of speed/rpm, above 43 mph with TCC engaged, was done by mhamilton with input from many CF members.
  7. Remove Advertisements
