2000 Deville Starter is stuck, Help
Results 1 to 8 of 8
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 2000 Deville Starter is stuck, Help in Past Cadillac Vehicle Discussion; I have a 2000 Deville DHS with a starting problem. My starter starts the engine and then keeps going and ...
    bkk.bob is offline Cadillac Owners Member
    Automobile(s): 2000 Deville DHS
    Oct 2013
    3
    Question2000 Deville Starter is stuck, Help
    I have a 2000 Deville DHS with a starting problem. My starter starts the engine and then keeps going and won't stop. Turning the key off doesn't stop it, it just keeps going. I had to disconnect the battery to get it to quit. When I reconnect the battery, the starter starts up with the key on or off. The engine starts ok but the starter won't stop. Is this a starter, or solenoid or relay problem and how do I get the starter to disengage?? I looked at the relays in the fuse box, they looked ok.
    I've looked at over 90 threads looking for a like problem but no luck.
    Mafiaman111 is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Deville 135K
    Oct 2010
    Pennsylvania
    446
    Re: 2000 Deville Starter is stuck, Help
    Have you checked for a short because I have seen this once before in a chevy silverado they could not figure out why the starter would keep going and turns out the plate that protected the started from debris had moved and made contract with the body of the truck and shorted it
    Feb 2003
    california
    69
    6,611
    I've seen this happen on a car with a weak battery! Not enough voltage to disengage the starter relay. I've also seen this happen if the start and run wires at the electrical ignition switch come together either in the switch contacts or the 2 wires melt together.
  5. #4
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    It doesn't take any power to disengage a relay, it takes a lack of it.
    Try swapping the relay first, it may just be sticking.
    BTW,
  6. #5
    Oct 2013
    3
    Quote Originally Posted by Mafiaman111 View Post
    I can't get to the starter to look for a short, on this model it's supposed to be under the intake manifold, which is a major undertaking. I will try swapping out the Relay to see if that helps.
    And I'm not sure how to check the Ignition switch. I will look to see what I have to do to remove it and look at the wiring. I've wiggled the key while the starter is going but that didn't do anything. I can shut the engine off by turning the key off but the starter keeps going and is trying to restart the engine, that's when I go and disconnect my battery.
    Thanks for the replies. Bkk Bob
    Swapping the Relay didn't help. I've also checked the battery and it's OK too.
  7. #6
    68
    81,748
    I think you have a bad starter or maybe solenoid.
    It's not as major a job as you think.
  8. #7
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,547
    The contact plate in the starter solenoid (on the side of the starter) is probably "welded" to the contacts. Not common, but it does happen. When the IGN start voltage from the key switch drops out, the solenoid does not pull off, thus keeping the starter itself running. The Bendix drive should disengage the pinion, but the motor will run all the time because the battery-starter positive cable is hot at all times.
    Intake manifold removal down in Tech Tips, or Google "cadillac forums 2000 deville intake manifold removal".
  9. #8
    Oct 2013
    3
    Thanks for all the help from everyone. Now at least I have a good idea of how to fix the starter problem. The battery checked out OK too. I will go after the starter now...
    Bkk.Bob
  10. Remove Advertisements
