No start - 2002 Deville
Results 1 to 14 of 14
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, No start - 2002 Deville in Past Cadillac Vehicle Discussion; I have a 2002 cadillac deville and when i go to start it i hear clicking sounds then when i ...
    02Cadillac is offline Cadillac Owners Member
    Automobile(s): 2002 Cadillac Deville
    Oct 2013
    Lawrence, Kansas
    26
    4
    UnhappyNo start - 2002 Deville
    I have a 2002 cadillac deville and when i go to start it i hear clicking sounds then when i try to start it again i hear nothing. I have power to my radio and my lights are bright my car just wont start. i replaced the battery and i even tried to get a jump when i replaced the battery. I have no clue what it could be can someone help me? PLEASE!!
    68
    82,076
    Re: Wont start help !!!
    I assume the battery cables are clean and tight?
    Might be a bad starter.
    Oct 2013
    Lawrence, Kansas
    26
    4
    @Ranger Yeah the cables are clean and tight, i was told it could be the spark plugs, alternator, starter, etc. i dont know what it could be
    Oct 2013
    Lawrence, Kansas
    26
    4
    UnhappyCar Will Not Start
    CadillacLuke24's Avatar
    CadillacLuke24 is offline Cadillac Owners Master
    Automobile(s): Alexandra - 96 SDV --- Clyde - 15 Silverado
    Jul 2010
    Wyoming
    26
    5,751
    Re: Car Will Not Start
    Sounds like the starter may be shot. Check the relay first, but I think you need to replace the starter.
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,395
    Quote Originally Posted by CadillacLuke24 View Post
    I'd bet on the fuel pump.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    I would have the battery load tested before anything else.
    The fuel pump has nothing to do with the car not cranking.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,253
    Re: No start - 2002 Deville
    It's not spark plugs ......... and probably not the alternator either - those have nothing to do with whether or not the engine rolls over during starter motor operation.
    You have problems with the starter, key switch, starter relay, low battery voltage, or TheftLock.
    68
    82,076
    to Deville forum
    Please do not double post. Threads merged.
    Andrew Armitage Guest
    Sounds like a bad starter. I had a starter go bad in an '06 DTS w/ 115k miles. Worked fine until it suddenly died at a gas station.
    I would hear one click upon turning the key to attempt to start it. If I tried again, I'd hear nothing. I would have to physically remove the key from the ignition and reinsert it and try to start the car to hear the one click again.
    Oct 2013
    Lawrence, Kansas
    26
    4
    QuestionRe: No start - 2002 Deville
    That's the Same thing Mines doing ... Did you Replace the Starter ? @Andrew
    thechef11 is offline Cadillac Owners Member
    Oct 2013
    My 2003 Devilleis doing the same thing. Had it in the shop at the Cadillac dealership an he changed the battery an then says it's a bad negative ground wire that runs from the engine block to the frame of the car...is this correct?
    Sent from AutoGuide.com Free App
    68
    82,076
    It's a possibility.
  16. #14
    Quote Originally Posted by 02Cadillac View Post
    Yes, starter was replaced. Problem was solved.
    Quote Originally Posted by thechef11 View Post
    It could be. I had a negative ground cable go bad on me about 5 years ago. The difference in that case was that there was no power to the car period. No lights, no radio, no nothing.
    In the case of the bad starter, everything works as is should but the engine doesn't turn over when you turn the key, it's almost as if you tripped the anti-theft device.
  17. Remove Advertisements
