93 Deville preignition or pinging
Page 1 of 2 12 LastLast
Results 1 to 15 of 23
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 93 Deville preignition or pinging in Past Cadillac Vehicle Discussion; I've tried everything I could think of and I can't get this pinging to go away. I always run premium, ...
    Jonathan11 is offline Cadillac Owners Member
    Automobile(s): 1993 Cadillac Coupe Deviile
    Jul 2013
    34
    I've tried everything I could think of and I can't get this pinging to go away. I always run premium, I even put octane booster in it.
    Checked the timing, changed the egr valve and egr solenoid, rodded out the egr ports in the throttle body and shot compressed air
    through the ports with the egr valve off, Checked fuel pressure, doesn't have a vacuum leak, did a decarb on the engine, I'm not getting
    codes, I'm out of ideas. Is there a way to check the spark control module? Is there anything else with the egr system? Is there a knock sensor circuit? Any help would be very much appreciated.
    scooter500's Avatar
    scooter500 is offline Cadillac Owners Fanatic
    Automobile(s): 2011 DTS super traveller
    Oct 2013
    on the coast in Virginia
    55
    126
    Re: 93 Cadillac Deville preignition /pinging please help
    Yes, there is a knock sensor. They are going for as low as $21 on ebay. Here's a recent post: http://www.cadillacforums.com/forums...r-diagram.html
    STS_Seville_Hunter is offline Cadillac Owners Enthusiast
    Automobile(s): 91 ETC, 91 STS, 98 Eldo Convertable, '93 Seville
    Sep 2008
    DHS/Palm Springs, CA
    29
    675
    Not on a 4.9
    Jul 2013
    34
    I keep hearing mixed feedback on that. rather or not there's a knock sensor. Most people tell me there isn't and a mechanic told me he'd be surprised if there isn't.
    Is there anything else on the egr system other than the valve and the solenoid? I rodded the egr ports out and the ports were caked with carbon. Is there a better way to clean those ports?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,885
    Re: 93 Deville preignition /pinging please help
    Octane "booster" - read the fine print. May boost octane up to X points ........ where X is a decimal, as in 87.0 octane to 87.2 octane "boost". Forget about using the stuff.
    When does the ping occur ?? All the time, all rpm, or only on light to moderate acceleration or - if at speed - moderate throttle application ?
    EGR usually pings during the above operations - bad timing or a bad (carbon tracked or cracked) distributor cap may ping almost all the time.
    69
    82,287
    The 4.9 DOES NOT have a knock sensor.
    rodnok01's Avatar
    rodnok01 is online now Cadillac Owners Master
    Feb 2012
    NC
    6,703
    When was the car tuned up? A weak ignition spark will cause a spark knock very easily.
    dennis93coupe's Avatar
    dennis93coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Coupe Deville, 2009 XLR-V 1 of 6 Crystal Red
    Feb 2010
    Orange County, CA
    62
    2,479
    [QUOTE=Jonathan11;11140489]I keep hearing mixed feedback on that. rather or not there's a knock sensor. Most people tell me there isn't and a mechanic told me he'd be surprised if there isn't.[COLOR="Silver"]
    Your mechanic is wrong. I own a 93 deville and I can guarantee there is not a knock sensor on it.
    houg is offline Cadillac Owners Fanatic
    Automobile(s): 81 supporter
    Sep 2011
    newington connecticut
    57
    383
    Quote Originally Posted by Submariner409 View Post
    toluene from any hardware or paint supply store is the best octane booster that u can buy, i always use it in my turboed hayabusa to help prevent detonation read\the link below
    http://sportscarforums.com/f13/tolue...oice-3257.html
    scooter500's Avatar
    Oct 2013
    55
    126
    Jonathan11 / Ranger / All, Real sorry! Part is actually listed for a 4.9L, plus Chevy went to those ~87... am really surprised.
    69
    82,287
    If you can find it and post a picture of it on your car, I for one would be very interested to see it. It certainly is not shown or listed in any of these diagrams.
    http://www.gmpartsgiant.com/Page_Pro...014&SortKey=12
    http://www.gmpartsgiant.com/Page_Pro...013&SortKey=15
    scooter500's Avatar
    Oct 2013
    55
    126
    I was thinking if there is no knock sensor then it makes sense that high octane is stated as required, even though the stock compression on a new 4.9L engine wouldn't seem to require high octane.. I'll keep pumping high(er) octane! Newb question... has anyone ever retarded timing to 9* or 8* to compensate in a knock situation like this?
    69
    82,287
    I don't think that would help as the PCM controls the timing. You only set the base timing and the PCM takes it from there. I'm guessing it would compensate for your compensation.
  16. #14
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,477
    It's not just compression that makes cars need higher octane it's also how it's tuned for performance.
    The computer might not compensate for the lower timing. That's usually what the knock sensor is for so the car can push the advance to it's limits. It was said around here before that you can set the timing a couple degrees lower if you aren't running premium gas. I'd just leave it alone and work on what the real problem is, but you're already trying to do that.
  17. #15
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    It's probably severely carboned up from a lifetime of slow driving. If it was mine I would run it hard (race a couple Mustangs) to see if it comes out of it. There could be something wrong with the PCM too. I would try another PCM 2nd. My 92 would never ping and I always ran regular fuel. Good luck.
  18. Remove Advertisements
