Is this part commonly changed with compressor?
Page 1 of 2 12 LastLast
Results 1 to 15 of 16
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Is this part commonly changed with compressor? in Past Cadillac Vehicle Discussion; Have to replace the compressor (& dryer, orifice, o rings)... noticed this part: AC Delco 15-1492 Refrigerant Filter Should it ...
    scooter500's Avatar
    scooter500 is offline Cadillac Owners Fanatic
    Automobile(s): 2011 DTS super traveller
    Oct 2013
    on the coast in Virginia
    56
    126
    Should it be changed too?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,180
    Re: Is this part commonly changed with compressor?
    It is always a good idea to replace an A/C filter/dryer during service. Use the GM/Cadillac service manual for the proper system evacuation procedure, PAG oil checks, and total pounds of refrigerant refill. (2.2, I think)
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,874
    Quote Originally Posted by scooter500 View Post
    YES - that is a particle filter -
    it protects the new compressor from sucking in debris -
    69
    82,402
    The system must have been repaired before because GM didn't include any refrigerant filters from the factory.
    scooter500's Avatar
    Oct 2013
    56
    126
    Quote Originally Posted by basscatt View Post
    This is great - really helpful so thanks everyone. One more "straighten me out here" question... I have an orifice on order (GM AC Delco A/C Air Conditioning Evaporator Fixed Orifice Tube White 15-5151... possible my '95 Deville will need the "yellow" colored orifice... took a 3 dollar chance & ordered blind ). Anyway, is this orifice a different/separate part from the AC Delco 15-1492 Refrigerant Filter or do the do the same thing?
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,874
    YES -
    steelybill is offline Cadillac Owners Enthusiast
    Automobile(s): '85 Fleetwood FWD
    Mar 2009
    mich
    85
    728
    Seems like changing a filter in the line is a good idea if the compressor failed, after the system is purged. Failed compressor may have dumped some debris into the system (?)
    69
    82,402
    True, but the system should be flushed of any debris. I really don't see much use for a filter. The orifice tube screen is so fine I always thought of it as a sort of filter. Besides that, the only debris that a filter would catch would come from a failing compressor anyway.
    scooter500's Avatar
    Oct 2013
    56
    126
    The compressor hasn't failed, but is leaking the green-colored oil. I've heard of drying the line through suction but a flush is a new for me. I thought if a compressor went you were stuck and it was time to change the entire A/C set-up. What is the basic process for an AC flush?
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,874
    then you do not need to flush the system -
    simply replace the leaking compressor -
    don't forget to add the correct amount of oil -
    I DO recommend replacing the receiver/dryer -
    the in-line filter protects the new compressor from debris -
    it's really cheap insurance -
    if a compressor blows - debris can be pumped through the system -
    you can flush MOST of the system -
    but you can not flush the condenser - so it would need to be replaced -
    69
    82,402
    You need a flush gun/kit something like this to flush each line. The solvent is basically mineral spirits.
    scooter500's Avatar
    Oct 2013
    56
    126
    Thanks, that a cool tool! I ordered the extra filter. Might as well with a new compressor going on....
    deleverage is offline Cadillac Owners Member
    Automobile(s): 99 Deville d'Elegance
    Jun 2012
    27
    Basscat, et al:
    My compressor failed and there is metal in the orifice tube. I am planning on replacing the compressor, condenser, installing a high side in line filter, and installing a new accumulator/drier. I was curious about the suction side filter but the ones I've seen are the ones with barbed ends. But the one called out in this thread has threaded ends. I was also looking at the small 'thimble' shaped screen (Brand = Airsept) that gets press fit into the inlet of the compressor and I am curious about what you think about them and their effectiveness.
    I met with a auto shop owner this afternoon in AZ and he cautioned against using the suction filters that require you to cut into the hose to install. Said that they all leak, and when the do, they take a lot of the oil with the leak and eventually cause the compressor to fail. So he doesn't install them for that reason and because of the leaks causing call backs. But the threaded one described here, how is that installed? I like the idea of having a filter on the suction side to protect the compressor, but don't want to cause more problems than it solves. I have heard that the accumulator/driers have a screen at the bottom to knock out debris. So if the evaporator was flushed, a new accumulator/drier installed, and the line to the inlet of the compressor flushed, would that catch most of the debris? A former GM tech that I spoke with this weekend said flushing is partially effective but not totally effective because the viscosity of the pag oil can cling to the inside of hoses and hold onto metal particles like a magnet. When the R134a (solvent) is added, it frees up the metal to go where it wants.
    Thanks for any experiences you may have.
  16. #14
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,874
    correct - the ACDelco 15-1747 is the one I recommend -
    $36.82 - with free shipping -
    http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER
    one word - HOGWASH -
    when PROPERLY INSTALLED - they are the most effective -
    and I can't ever remember one leaking -
  17. #15
    Jun 2012
    27
    Thanks Basscat, I have been corresponding with Rodnok and he has had good luck with the inlet filter as well. I think I will go that way as good insurance for the compressor.
    Appreciate your insights and experience.
    Basscat, one other thing, what kind of clamps do you use on the suction line filter? I was thinking about using Oetiker clamps and didn't know if you had a better alternative to consider.
  18. Remove Advertisements
