I want to change the transmission fluid and filter in my 92 deville.
Results 1 to 5 of 5
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, I want to change the transmission fluid and filter in my 92 deville. in Past Cadillac Vehicle Discussion; Is this a straight forward process? The car has 189,000km The previous owner had the transmission serviced about at 145,000kms. ...
    kompressor1 is offline Cadillac Owners Member
    Automobile(s): 1992 deville
    May 2011
    49
    48
    Can I do this myself?
    68
    82,055
    Re: I want to change the transmission fluid and filter in my 92 deville.
    It is straight forward. Drop the pan (it's very messy). Start at one corner and remove the bolts from there in both directions so as the pan lowers it will somewhat funnel the fluid into your drain pan. The if I remember correctly, the filter just pulls out. Check to be sure that the O ring comes with it or if it doesn't, don't put another one in. The gasket is reusable.
    dennis93coupe's Avatar
    dennis93coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Coupe Deville, 2009 XLR-V 1 of 6 Crystal Red
    Feb 2010
    Orange County, CA
    62
    2,479
    Not an oring. There is a metal sleeve with a rubber seal where the filter slides up into the transmission. Just make sure that sleeve does not come out with the filter. The gasket is reusable but over time they get seperation of the rubber from the metal core. Look it over real close before you put it back on. I like a clean dry transmission so I always replace the gasket, expensive but just me.
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,449
    Gaskets are cheap, even tho they are reusable I always replace it if it's been on there a long time.
    I usually leave the filter seal alone unless it just pops out easily or is damaged. I can't remember if there is any screws holding the filter but you'll see them if there are.
    68
    82,055
    Quote Originally Posted by dennis93coupe View Post
    Oops, I stand corrected. Thanks Dennis. It's been some time since I've been under a 4T60E.
  8. Remove Advertisements
