98 Deville sunroof
Results 1 to 3 of 3
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 98 Deville sunroof in Past Cadillac Vehicle Discussion; Is there a diagram or manual of the factory installed sunroof on a 98 deville? mine seems to be loose ...
    lestro is offline Cadillac Owners Member
    Automobile(s): 98 deville base
    Sep 2013
    Benton,IL
    37
    98 Deville sunroof
    Is there a diagram or manual of the factory installed sunroof on a 98 deville? mine seems to be loose (not solid ) on right rear corner of glass and doesn't seem to stop correctly.Chilton doesn't cover it. It also leaks, but I'm in the process of trying to clean the drains. thanks in advance
    68
    81,926
    Re: 98 Deville sunroof
    The only manual that will cover it is a FSM by Helm Inc. www.helminc.com. Chiltons or Haynes won't even mention it. Ebay is your friend.
    The only other option is a subscription to www.alldatadiy.com/
    Sep 2013
    Benton,IL
    37
    thanks
