Time Trouble... Clock Giltch
Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By arctic_man
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Time Trouble... Clock Giltch in Past Cadillac Vehicle Discussion; So, I didn't drive the SDV for a couple of days. I just took it out for a few errands, ...
    Faith76's Avatar
    Faith76 is offline Cadillac Owners Enthusiast
    Automobile(s): 89 Sedan DeVille, 90 Fleetwood, 94 Fleetwood Hearse
    Jul 2013
    Fredonia, NY
    41
    557
    So, I didn't drive the SDV for a couple of days. I just took it out for a few errands, and every time I turn it off, and then back on, the clock resets to 1:00. Every time. WTF is going on?
    It's the factory radio/clock by the way.
    arctic_man's Avatar
    arctic_man is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Deville
    Jun 2008
    The Sticks, MN
    27
    266
    Re: Time Trouble... Clock Giltch
    Not sure how some of the other cars are, but if I were to guess, I would say the cmos battery built into the stereo is bad. Cmos in electronics is responsible for providing a low amount of power to keep things like time, bios, and ram/rom active when power has been cut; like turning off the car. To fix it, you have to replace the battery. In this case, I would not know where it is. Typically it is on the circuit board it is providing power for. But getting to it may be another issue...
    Faith76 likes this.
    Submariner409's Avatar
    Submariner409 is offline If it won't run, stick on fender vents
    Feb 2006
    MD Eastern Shore, Kent Island
    56,606
    How old is the 12 volt car battery ??? Some cars/models/radios will reset the clock to 12:00 or such on a low voltage startup - and, yes, the radio onboard memory battery may also be at fault.
    Faith76's Avatar
    Jul 2013
    Fredonia, NY
    41
    557
    New battery 06/16/09 at 39,600 miles. 14,000 miles ago.
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,873
    4 yr old battery, id get it tested..
    Faith76's Avatar
    Jul 2013
    Fredonia, NY
    41
    557
    Well, I took the car and had the battery tested and it checked out fine. Also, in what may or may not be a related matter, the horn has stopped working. I guess the gremlins are coming out for Halloween. Is there a fuse for the horn I could check? Is it possible the two issues are related? Should I start a new thread for the horn?
    I FIXED IT!!! Oh, I'm so proud LOL. I went through my manual and figured out that the number 11 fuse was for the radio AND the horn. I replaced it and it everything works now!! The small pleasure in life!
  9. Remove Advertisements
