ABS pumps @ 3mph - 1991 Deville
Results 1 to 4 of 4
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, ABS pumps @ 3mph - 1991 Deville in Past Cadillac Vehicle Discussion; I just got a 91 Deville. In the morning after the car has sat in the garage, when I drive ...
    John Gronberg is offline Cadillac Owners Member
    Automobile(s): 1991 Deville
    Jul 2013
    Geneva, IL
    34
    I just got a 91 Deville. In the morning after the car has sat in the garage, when I drive down the street I can here the PMV running for about 2 seconds. This is the only time it happens. After reading in the Haynes manual it indicates this is, "The Pressure Modulator Valve (PMV) will often be heard running at slow speeds as it cycles through the ABS self-test mode." Is this correct?
    (e-mail removed)
    Moderator edit: NEVER post your e-mail in a worldwide forum - you might just get far more than you bargained for. Let the forum work for you. Thanks.
    Moved from Catera to Deville.
    Mafiaman111 is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Deville 159k
    Oct 2010
    Pennsylvania
    449
    Re: ABS pumps @ 3mph - 1991 Deville
    all I know is the ABS Pump will do a self test as soon as the car is started but that's for obd II cars not sure if the same applys for obd I
    69
    82,386
    Can't swear to it, but I think Haynes may be correct. That said, I would put far more faith in a FSM by Helm Inc.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,156
    Both our 91 and 92 Taurii (OBD1) did a one second ABS self-test at about 3-5 mph after start. RRRRRRtttttttt!!!!!
  7. Remove Advertisements
