Deville won't start
Results 1 to 15 of 15
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Deville won't start in Past Cadillac Vehicle Discussion; Left light on in car did boost and car started. Next day no start. Tested batt. had a bad cell ...
    phut7 is offline Cadillac Owners Member
    Automobile(s): Cad-Deville 1991 4.9L 300K miles
    Aug 2009
    74
    Deville won't start
    bad cell in the old battery so bought a new one. Now still the car won't turn but dash
    and lights are fine and bright nothing else
    rodnok01's Avatar
    Feb 2012
    NC
    6,650
    No crank or no start?
    Aug 2009
    74
    Re: Deville won't start
    no crank, no starter noise, just a little noise in cabin right side little click
    rodnok01's Avatar
    Feb 2012
    NC
    6,650
    Check battery and connections, you could have fried something. Check fuses(Maxi's too) and might check the codes too.
    Aug 2009
    74
    Please tell me what is Maxis
    68
    82,056
    Maxi fuses.
    rodnok01's Avatar
    Feb 2012
    NC
    6,650
    That's funny right there... They ain't made by Always
    I can't remember if there is a starter relay, but believe there is.
    Aug 2009
    74
    I checked all the fuses on the car that I could find. Not sure where the Maxi fuses are.
    68
    82,056
    Can't recall for sure, but maybe up by the firewall on the passengers side? The owners manual will tell you for sure.
    Aug 2009
    74
    The new battery is no longer fully charged after only 1 night.
    Have to recharge battery then will check maxi fuses I believe under the hood by reservoir tank. How can I tell if the relays are bad? The fuse will be broken but the relays?
    Aug 2009
    74
    Still need help new battery but car will not crank or start. The strange thing is that the battery seems to drain quickly. I gave car a boost when I put key in ignition during boost the lights inside were bright. Then when I turn they turned dim. After that the power seems to be drained. Any ideas?
    68
    82,056
    I think you need to put a 12v test lamp in line between the negative cable and the battery terminal. If you have a voltage draw it should illuminate. Start pulling fuses until it goes out.Then you'll know what circuit or component to concentrate on.
    Aug 2009
    74
    Ok I will try this eve.
  16. #14
    Aug 2009
    74
    Ok I ddi the test and found out that the truk pull down swith was the problem It was pulling 11 volts accoding to meter. I pulled fues and no prolem starting dorve car today.
    Can I replace trunk with regular trunk lock instead of the automatice one?
    Thanks again for all of your help really appreciate it!
  17. #15
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    You can take the motor off the trunk pull down and screw down the mechanism and leave the motor unplugged and it will work like a regular car trunk.
  18. Remove Advertisements
