New Alternator New Alternator Plug
Results 1 to 4 of 4
Like Tree2Likes
  • 1 Post By carnut
  • 1 Post By carnut
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, New Alternator New Alternator Plug in Past Cadillac Vehicle Discussion; Im not sure if this is the new battery or something else but the charge still wont go over 13.5??? ...
    SUPER LAC DEVILLE's Avatar
    SUPER LAC DEVILLE is offline Cadillac Owners Enthusiast
    Automobile(s): 1998 Cadillac Deville
    Aug 2012
    Tampa Florida
    38
    854
    Any Ideas???
    Feb 2003
    california
    69
    6,666
    Re: New Alternator New Alternator Plug
    Yes, the battery is fully charged and there's no need to raise the charge output. Try leaving the lights on for a half hour and immediately read the battery voltage at the battery posts once you restart it. The best test is not voltage but amperage. A shop can measure voltage output but can also load test the battery to see if amperage increases as more load is applied as the car runs. If the alternator is, say, a 100 amp unit, it should be able to produce almost 100 amps under extreme load. 13.5 is only .7 volts away from an ideal charging voltage output.
    SUPER LAC DEVILLE likes this.
    Aug 2012
    Tampa Florida
    38
    854
    Yea, the highest it got to was 13.9
    but i thought proper charging voltage for my car running was 14v/14.4v???
    walmart tested the battery and it had a 680ish cca (650 cca battery) and a 13.1 charge
    my old dead and gone battery usually sat between 14/14.4v (car running)
    jus wanna be sure its ok???
    Feb 2003
    california
    69
    6,666
    14.4 is an ideal max voltage output. Anything past that will burn out bulbs quickly. Again, you need a LOAD test done to confirm the alternator amperage output is within spec. And the reason the old battery read 14.4 was because the alternator was its life support! It was trying to keep the old battery up.
  7. Remove Advertisements
