Alternator for 1998 Deville
Results 1 to 6 of 6
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Alternator for 1998 Deville in Past Cadillac Vehicle Discussion; I think my alternator is going out. It has a noisy bearing. Does anyone have parts recommendations? GM, rebuilt, remanufactured? ...
    trod is offline Cadillac Owners Member
    Aug 2013
    3
    Are there any other parts that should be changed out as long as the alternator is being replaced?
    Any tips or suggestions would be greatly appreciated.
    What is the life expectancy of an original Cadillac alternator?
    Thanks in advance,
    T-Rod
    Submariner409's Avatar
    Submariner409 is online now If it won't run, install a boombox
    Feb 2006
    MD Eastern Shore, Kent Island
    56,577
    Re: Alternator for 1998 Deville
    Life expectancy depends on age, miles, average engine speed, the phase of the moon and the price of corn on the commodities market.
    Use an AC Delco alternator - talk to Chris in parts at Rippy Cadillac over there >>>>>>>>>>>
    Murderous job.
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,873
    Its shouldnt be too difficult if you can get the car high up enough. 3 ton hydraulic jack would be best. At least it wasnt so, on mine
    Goldencletus is offline Cadillac Owners Fanatic
    Automobile(s): 1998 DeVille Concours, 2004 Nissan 350Z Roadster
    Feb 2013
    Gold Country of California
    60
    109
    Mine went out a month ago, no noise, no warning. When it stopped working, the dash info said "Battery not Charging". I was on the freeway and went about 10 miles and the car completely shut down, and I mean completely shut down. Had to get it towed and then I was at the mercy of a Sears mechanic 100 miles from my house, expensive. If you think it's going out, I would get it tested and if it is, replace it now before it strands you!
    SUPER LAC DEVILLE's Avatar
    SUPER LAC DEVILLE is offline Cadillac Owners Enthusiast
    Automobile(s): 1998 Cadillac Deville
    Aug 2012
    Tampa Florida
    38
    854
    i Jus went thru this last night...
    Except instead of calling a tow truck i hooked up my Battery Jumper Box to the battery, sat it towards the front over the cooling fans and closed the hood to the first latch on top of it... it got me home 12miles away... the jumper box kept the battery at about 12.9 but by the time i got home it was at 12.7
    Feb 2003
    california
    69
    6,680
    Get a DELCO remanufactured, not rebuilt. A rebuilt by definition means only the defective parts were replaced. A reman. will have all new parts inside. And fellas, he's not describing a failing alternator, he's saying its noisy.
  9. Remove Advertisements
