Best oil drain plug seal?
Results 1 to 6 of 6
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Best oil drain plug seal? in Past Cadillac Vehicle Discussion; My '96 DeVille's sump drain plug is leaking badly. Before I drain the oil and replace whatever seal it has, ...
    cormorant is offline Cadillac Owners Member
    Automobile(s): '96 Sedan DeVille
    Oct 2013
    70
    21
    My '96 DeVille's sump drain plug is leaking badly. Before I drain the oil and replace whatever seal it has, would like to know what has been found to be best part for the job: O-ring, red fiber washer, aluminum washer, metal crush washer?
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,476
    Re: Best oil drain plug seal?
    Quote Originally Posted by cormorant View Post
    the correct drain plug has a rubber seal built in -
    no additional seal or gasket should be necessary -
    rodnok01's Avatar
    Feb 2012
    NC
    6,651
    I picked up a replacement at Advance that was of very good quality and stopped my leak.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,202
    The Help! racks at parts stores have various sizes of oil drain plug washers - a gray hard silicone type.
    Oct 2013
    70
    21
    Thanks for the tips; don't know if my plug is original or not, but will see what I've got when I pull it out!
    CadillacLuke24's Avatar
    CadillacLuke24 is offline Cadillac Owners Master
    Automobile(s): Alexandra - 96 SDV --- Clyde - 15 Silverado
    Jul 2010
    Wyoming
    26
    5,751
    Yeah if yours is leaking go hit up a parts store and get a new one. I do believe I have the factory plug and it does not leak. AT ALL.
  9. Remove Advertisements
