Exhaust system issues
Results 1 to 8 of 8
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Exhaust system issues in Past Cadillac Vehicle Discussion; I had a small exhaust leak n the front of my exhaust system by the converter and the pipe that ...
    tarintino07's Avatar
    tarintino07 is offline Cadillac Owners Member
    Jun 2013
    39
    I had a small exhaust leak n the front of my exhaust system by the converter and the pipe that extends to the motor. . Somehow I guess the clamp came off and of course the car is loud and I'm not driving it at the moment . So my question is can this part of the system be welded back together ? Or does it just need another clamp perhaps . I don't think I'm driving the car No longer than 2 months from now . If a clamp or weld will work I will just do that for the moment.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,374
    Re: Exhaust system issues
    Quote Originally Posted by tarintino07 View Post
    without pics - there is no way to tell what needs fixing -
    why not take the car to an exhaust shop -
    and ask for an estimate?
    Jun 2013
    39
    Ok I will take the pic of it tommorrow
    Lewis98272 is offline Cadillac Owners Fanatic
    Automobile(s): '02 Eldorado ETC 85k miles / Past: '03 Deville; '02 STS
    Aug 2013
    Texas
    176
    Do any of you happen to know the exhaust pipe diameter of an 03 deville? I'm replacing my mufflers with super 44 flowmasters, but I can't seem to find the diameter... Also, will it sound better if I replace the resonator with a straight pipe, or will that be way to loud?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,934
    The pipe diameters vary all over the place at the Y and mufflers - due to the roll bending jig setup used to make the OEM systems. You'll need to cut and measure - then weld in proper adapters. Some of the original 2", 2 1/4", and 1 3/4" piping actually gets squashed down to 1 5/8" or so.
    The resonator would probably best be left in - it doesn't do all that much anyway. Your call.
    Here's the Y end of an original 2002 Seville system - practically identical ......... makes you want to replace it all, doesn't it ?
    Compare that Y to the CORSA pictures in my albums.
    Aug 2013
    Texas
    176
    Alright, thanks! I appreciate the help.
    Jun 2013
    39
    Got the pipe welded at rainbow mufflers so it should be ok for a while til I get some money to do the whole exhaust. I heard the intermediate pipe is hard to find is that true
    Feb 2006
    55,934
    NAPA - or take a look at the system parts in your year/car/model in either www.rockauto.com, www.gmpartsgiant.com, or www.AutoPartsWarehouse.com
  11. Remove Advertisements
