Help With Brake Light Issue Please
Results 1 to 8 of 8
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Help With Brake Light Issue Please in Past Cadillac Vehicle Discussion; I have a 2005 Deville. On a recent road trip the Brake Light came on after I was parked at ...
    JimmyInDenver is offline Cadillac Owners Member
    Automobile(s): 2005 DeVille
    Sep 2013
    4
    I have a 2005 Deville. On a recent road trip the Brake Light came on after I was parked at a friends house for several hours when it had never came on before. The brakes are fairly new and work fine and as I was driving at night the light was annoying so when I stopped I wiggled the ignition switch and it went off. The issue I am having is that my code reader now gives me a Yellow code indication a "Possible Problem" but does not give me a code thus it won't let me clear a code. Any Ideas?
    reppinshadyvill is offline Cadillac Owners Fanatic
    Automobile(s): 2003 DTS
    Nov 2012
    Central FL
    34
    205
    It's probably nothing. Use the onboard code reader that's installed in the car to pull the code. Check the stickies at the top to see the procedure.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,907
    Re: Help With Brake Light Issue Please
    Fixed - Incorrect info.
    Crawl into the driver's footwell and check that the brake lamp switch is properly snapped into its mount.... top of brake pedal arm.
    ??? When did these cars lose user-controlled OBD ? 2004 or 2005 ?
    Sep 2003
    Metro ATL
    4,854
    Quote Originally Posted by JimmyInDenver View Post
    Several ideas and a question or two before I do a lot of typing.
    Learn how to display trouble codes with your diagnostic display. Go here and scroll down to your year model for instructions.
    http://www.cadillacforums.com/forums...odes-dtcs.html
    Does your cruise control work?
    Feb 2006
    55,907
    That answers my question - obliquely.
    Sep 2003
    Metro ATL
    4,854
    Quote Originally Posted by Submariner409 View Post
    His car does not have user-controlled diagnostics. He would need to go to a large parts store and have them scan it - or use his hand-held unit.
    Devilles had onboard code display through 2005. Sevilles through 2004 as explained in the sticky; "DTC display; 1998-2004 Seville, 2000-2005 Deville and other models with 3 buttons on the RH side of DIC"
    Sep 2013
    4
    Everything on the car works great. 3 weeks ago I would get a green light with the OBD II now I always get yellow...I'll check the brake switch...
    Sep 2003
    Metro ATL
    4,854
    Except the brake light I guess.
    That must refer to some aftermarket portable code reader.
    What you really want to know is are there any "B" codes or "C" codes set. Most aftermarket code readers will not display "B" or "C" codes. Learn and use the method in the sticky thread previously posted.
  11. Remove Advertisements
