Results 1 to 8 of 8
Thread: 2003 deville elc pump
    houg is offline Cadillac Owners Fanatic
    Automobile(s): 81 supporter
    Sep 2011
    newington connecticut
    57
    383
    i have a few questions about the elc pump on a 03 deville
    1 is the pump suppose to come on every time that the car is started?
    2 is there some sort of electronic check valve in the pump that hold,s the air until the car is shut off?
    every time i start my car the pump comes on for 5 to 10 seconds, if i shut the car off and restart it right away it comes on again, i would think if it was shut off and restarted it shouldnt come on right away
    and if i drive it down the road 5 minutes after staring it it will come on again, some times i can drive for many miles and it wont come on, other times it will come on ever few minutes, i sprayed every thing that i can see (lines and shocks) with soapy water and i see no leaks but i cant spray around the pump cuz its enclosed, would always having a full tank of gas make it come on more often? when my fuel get to one bar below full i always top it off (anal)
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,689
    Re: 2003 deville elc pump
    Quote Originally Posted by houg View Post
    YES -
    YES - actually an EXHAUST VALVE - built into the compressor head -
    CORRECT - that is the "self-test" -
    you have a leak in the system -
    either the compressor - the air supply lines -
    or most common - in the shocks -
    NO - the compressor should come on when the load changes -
    I believe you have a leak somewhere -
    check for codes - the exhaust valve IS monitored -
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,842
    Exact truth ^^^
    (IF the system is tight the self-test is only ~2 seconds.) .......... otherwiase the system has to work to level the car after sitting.
  5. #4
    Sep 2011
    57
    383
    am i correct by saying the only way i can access the pump is by dropping the exaust/ tail pipe????
  6. #5
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,689
    yes
  7. #6
    Sep 2011
    57
    383
    on the EXHAUST VALVE - built into the compressor head, does it let out all the air in the system when the car is shut off??? ifso then i would imagine that the compressor pump would have to run for more than 2 seconds like submariner said at startup to refill the system???
    im just trying to understand the way the system works
  8. #7
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,689
    NO -
    to over simplify -
    there is a level switch under the car -
    this switch has a predetermined setting where "level" is -
    when there is a load in the back seat and/or trunk - and the rear sits too low -
    the level switch turns on the compressor -
    to inflate the air bladders built into the shocks -
    thus raising the body - back to the predetermined "level" position -
    when the load is eliminated - the rear will sit too high -
    so - the level switch activates the exhaust valve built into the compressor -
    and releases the air from the bladders -
    until the car drops down to the predetermined "level" position -
    the minimum air pressure in the bladders is 14PSI -
  9. #8
    69
    82,272
    If you want to verify that, simply reach in over the tire, remove the retainer clip and pull the plug. You should hear air release.
  • You may not post replies
