2003 deville starts then immediately dies.
Results 1 to 15 of 15
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 2003 deville starts then immediately dies. in Past Cadillac Vehicle Discussion; I hadn't started my car for only 2 days then today I had this happen. It started fine then died ...
    purelux is offline Cadillac Owners Fanatic
    Automobile(s): 2003 deville
    May 2011
    484
    I hadn't started my car for only 2 days then today I had this happen. It started fine then died instantly, tried again same would stay running with foot on gas. Let off gas died, tried again kept at about 1200 or so for a few minutes stayed running but 450 ac on-500 off. After driving it slowly increased idle each stop light I hit until back to 625-650 like normal. Only code was rim u1016 history. However voltage normally is 15 today it showed 14.8 then slowly over 20 or so minutes down to 14.3. Drove again 3 hrs later and went 14.9-14.5. Any ideas I've had a IAC go bad or stick, battery and alternators go bad but nothing like this???
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    When was the TB last cleaned.
    68
    81,916
    Re: 2003 deville starts then immediately dies.
    I put my money on a dirty TB before the IAC valve. The IAC bypass channel is probably carboned closed.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,881
    Your indicated system voltages are correct. Indicated voltage will be 12.2 to 12.5 volts with key on, then it goes high just after start as the alternator/regulator jams amps back into the battery at elevated voltage. As internal battery resistance (state of charge) rises, the charging rate ramps down to a constant 14.2 to 14.5 voltage with only enough amperage to handle the exiting electrical loads.
    The poor idle quality and stalls should not be battery/system related with your stated voltage sequence. 2003 Deville ??? I'll also advise TB and IAC cleaning.
    For alternator/regulator operation, look into www.balmar.net. For lead-acid battery theory and charging, Google "lead acid battery charging" or any of the leading battery manufacturer websites and read the tech articles. www.rollsbattery.com
    May 2011
    484
    Tb and iac were cleaned maybe 2 or 3 months ago. Though ill check/clean again soon as weather cooperates.
    68
    81,916
    In that case it may be a failed IAC valve, but I would expect that to set a DTC.
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    is the check engine light on?
    if so, pull the codes...
    68
    81,916
    I suspect the light must be on with P1599-stall or near stall detected..............duh!
    Sep 2007
    Wilmington, NC
    13,986
    yeah... but what else? maybe some of the history codes might help also
    68
    81,916
    Maybe Chris.
    P.S.
    The "duh" was aimed at the code definition, not you. Hope yo didn't take it that way. Didn't think about it til I just reread it.
    Sep 2007
    Wilmington, NC
    13,986
    ah... yeah i wasn't really sure... figured i knew you better than to assume the worst
    May 2011
    484
    Sorry forgot to post, definition is serial communications malfunction.
    68
    81,916
    Thanks Chris, I appreciate the vote of confidence.
  16. #14
    simdude85 is offline Cadillac Owners Member
    May 2013
    I have an 02 that had the same problem. I replaced the iac and she is back working like new
  17. #15
    bigtone's Avatar
    bigtone is offline Cadillac Owners Enthusiast
    Automobile(s): 2010 DTS, 2006 DTS, 2001 Deville,
    Jun 2003
    544
    My 01 Deville failed the same way. Start, but instant stall. New IAC fixed it.
  18. Remove Advertisements
