2000 Deville Dies after A/C is turned on
Results 1 to 7 of 7
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 2000 Deville Dies after A/C is turned on in Past Cadillac Vehicle Discussion; Turned on the car tonight a/c was set to full heard a clunk and the car died, did a restart ...
    steamboat519 is offline Cadillac Owners Member
    Automobile(s): 2000 Deville Base
    Jul 2012
    34
    8
    Turned on the car tonight a/c was set to full heard a clunk and the car died, did a restart no clunk but the rpm's dropped dead in about 5 seconds, then turned the car back on with no a/c drove for a bit then turned a/c on again and it died with in about 5 seconds unless I kept my foot on the gas no codes except for 1599 any ideas? Battery is good. Thanks
    reppinshadyvill is offline Cadillac Owners Fanatic
    Automobile(s): 2003 DTS
    Nov 2012
    Central FL
    34
    205
    Re: 2000 Deville Dies after A/C is turned on
    Your A/C compressor is probably seizing up and bogging down the engine.
    68
    82,076
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    What's the code definition?
    The only other explanation would be a faulty IAC valve. But that wouldn't clunk.
    Black Beauty DTS's Avatar
    Black Beauty DTS is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Cadillac DeVille DTS
    Apr 2012
    285
    Quote Originally Posted by steamboat519 View Post
    Yeah, it sounds like when the A/C compressor clutch engages, it dies because the compressor is creating too much of a drag on the engine. It could be a bad bearing due to lack of oil caused by a leak somewhere in the system. Did the A/C making any strange noises like a squeaking or squealing sound before it started doing this?
    Sep 2010
    East Boston MA.
    29
    26,325
    The bearings aren't lubed by the oil in the refrigerant, they're sealed bearings.
    Apr 2012
    285
    I stand corrected. I was thinking of another car that I had to change the compressor out, due to a bad bearing caused by the PAG oil leaking out with the R134a.
  10. Remove Advertisements
