Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Thread: Aftermarket Keyless Entry
    trailor's Avatar
    trailor is offline Cadillac Owners Fanatic
    Automobile(s): 00 Deville DTS, 120K Miles
    Apr 2013
    The Bus, Ohio
    157
    Can I use one or am I stuck going to the dealer? My car is a 2000 and I've read most is a dealer option. True or false?
    69
    82,278
    Re: Aftermarkert Keyless Entry
    Have you tried Ebay? You'll probably still have to have a dealer program it.
    trailor's Avatar
    Apr 2013
    The Bus, Ohio
    157
    Program for driver one and drive two? That's the only thing I've read. I'm just talking about a basic unlock and lock from amazon.
  5. #4
    69
    82,278
    If you buy 2 I'm guessing you'd have to have 2 programmed.
  6. #5
    trailor's Avatar
    Apr 2013
    The Bus, Ohio
    157
    So programming any remote would have it register to "driver 1" and "driver 2?" Well it's only 18 bucks on Amazon. I might give it a try to just do the basics and if it only unlocks and locks, I'm just fine.
  7. #6
    rodnok01's Avatar
    Feb 2012
    NC
    6,701
    Are you just looking for key fob or an addon keyless entry system?
    The aftermarket systems do not use factory alarm system IIRC, so you you want that to work may have to stick with OEM fob's off ebay.
  8. #7
    trailor's Avatar
    Apr 2013
    The Bus, Ohio
    157
    Adding keyless entry. I didn't think about the security party. Poop.
  9. #8
    13ir14314's Avatar
    13ir14314 is offline Cadillac Owners Fanatic
    Automobile(s): 1967 Eldorado
    Jan 2012
    Minnesota
    22
    443
    I'm sure key less entry had to be standard for these cars if not its a very common factory option. find a remote on eBay for $4. You will have to bring it to the dealer to have the fob programmed. If your car has the memory option the remote will have a #1 or #2 on the back to correspond with that driver. Either remote number can be programmed to #1 though, so you'll only need one fob.
  10. #9
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Anti theft/keyless entry was standard.
  11. #10
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,854
    The car already has keyless entry, driver recognition, keyless trunk and fuel door - controlled by the key fobs. The lock/unlock buttons also control the TheftLock system on/off.
    You should have received 3 keys - 2 black, one gray, and 2 remotes, #1 and #2.
    Read the owner's manual on personalization using key fobs 1 and 2. The later key fobs are programmed by a GM dealer.
    Here's your key fob ........... and adding another remote on top of the one already built into the car will be a nightmare of compatibility and electronic/electrical problems.
  12. #11
    monty_n_philly is offline Cadillac Owners Member
    Automobile(s): 03 Deville, DTS
    Apr 2013
    42
    69
    I found 2 things... Youtube vid and link explaining it...
    http://www.youtube.com/watch?v=C82072RDekg
    http://answers.yahoo.com/question/in...7202721AA29Xms
    Hope this helps, i have to do 1 of my keyfobs as well
  13. #12
    Sep 2010
    East Boston MA.
    29
    26,323
    '00+ Deville fobs cannot be paired without a TECH II.
  14. #13
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,697
    Quote Originally Posted by monty_n_philly View Post
    will NOT work
    Quote Originally Posted by 13ir14314 View Post
  15. #14
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,476
    If you want to add a new system just goto a shop that does that type of thing and let them deal with it all. But like others said why go aftermarket when the car should already have it?
  16. #15
    13ir14314's Avatar
    Jan 2012
    Minnesota
    22
    443
    Quote Originally Posted by basscatt View Post
    I've gotten them for that price twice, they were of couse well used but worked just fine.
  • You may not post replies
