Rear left trans mount replacement 2000 deville
Results 1 to 5 of 5
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Rear left trans mount replacement 2000 deville in Past Cadillac Vehicle Discussion; Anyone havea DIY or tips replacing the less common rear or left transmission mount on a 2000 deville? It is ...
    EuroCad is offline Cadillac Owners Member
    Automobile(s): 2000 Deville Base
    Oct 2004
    California
    88
    Anyone havea DIY or tips replacing the less common rear or left transmission mount on a 2000 deville? It is the one towArds the rear of the car. Square shaped mounted to the cradle. Mine looks shot. Almost hollow. Is it easy or a good thing to have a shop do?
    Oct 2004
    California
    88
    Re: Rear left trans mount replacement 2000 deville
    Wait maybe it isn't bad. It is supposed to be hollow with just a small piece of rubber in the middle? Looking at a picture it is like that new. How would you tell if this is bad? I am trying to track down an annoying clicking noise when putting car in reverse at high idle. Front mount is new.
    69
    82,272
    It the front mount that failed. The other 3 almost never do.
    Does it click all the while in reverse or only while shifting?
    Oct 2004
    California
    88
    Only while shifting it makes the click. Good to know about the other mounts I think it might be the hub bearing actually. When shifting listening closely near the wheel it is coming more from the wheel area than motor.
    rodnok01's Avatar
    Feb 2012
    NC
    6,701
    Never heard a hub bearing make noise when shifting into gear. CV yes, hub no.
  8. Remove Advertisements
