Bad coil ? 2004 DHS
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 23
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Bad coil ? 2004 DHS in Past Cadillac Vehicle Discussion; Can a bad coil cause the engine to jerk/jump. Coil 2 is bad on my car according to a mechanic ...
    GM_Ridin' is offline Cadillac Owners Fanatic
    Automobile(s): 2004 cadillac deville dhs
    Jan 2012
    san diego
    29
    414
    Bad coil ? 2004 DHS
    Can a bad coil cause the engine to jerk/jump. Coil 2 is bad on my car according to a mechanic altho theres no fault code coming up for it. It doesn't do this jerk/jump all the time but when it does it's usually when in park or when my foot is on the brakes.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,936
    Re: Bad coil ? 2004 DHS
    A 'bad coil' - no spark to a plug - would cause a miss most or all the time, probably most evident at slow speed or idle. Yes, the engine would shudder. A bad fuel injector would cause almost the same problem(s).
    Jan 2012
    san diego
    29
    414
    Quote Originally Posted by Submariner409 View Post
    Hmmm ok thanks a mill sub. Oh and 'shudder' you hit it dead on! I was trying to find the best explanation and you got it. Yeah my mechanic told me a while back that coil 2 was bad and I almost forgot all about it. But I need to change that asap because I just changed out my spark plugs. There's no SES showing up for it though... unless it shows up when pulling codes from the DIC...?
    Also does anyone have a chart showing which # coil is which?
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    #2 coil = the coil for cylinder #2. Front bank, second in from the left when standing in front of the car.
    1 3 5 7
    2 4 6 8
    Feb 2006
    55,936
    Didn't 2004 go to the actual coil-on-plug racks - 4 separate, replaceable coils, bolted to a s/s plate ? (and the individual coils are sort of hard to find .....)
    Sep 2010
    East Boston MA.
    29
    26,325
    Yeah, edited my post a while ago. Didn't notice the year.
    Jan 2012
    san diego
    29
    414
    1 3 5 7
    2 4 6 8
    Oh ok this is simple enough! Odds in the rear left to right and evens in the front left to right.
    I just reread what you posted... "front bank second in from the left if standing in front of the engine"... so is that or is it just like the number sequence you wrote?
    Whoa wait what is this?? Either I misunderstood what the mechanic ment for coil or I simply dont have this. I thought the coil was the boot/wire thats held in by a star screw thats covering the spark plug?
    Sep 2010
    East Boston MA.
    29
    26,325
    The boots (with coil springs inside, essentially short plug wires) are attached to the coils. Coil/boot assemblies are usually sold as sets of 4 though.
    I initially posted info on the '00-'03 ignition system, totally different than yours.
    Feb 2006
    55,936
    Yeah, that ^^^
    Here's the 2000 - 2003 Northstar coil cassette setup - one cassette on each bank.
    Jan 2012
    san diego
    29
    414
    Oh ok thanks for clearing that up guys. So as for the coil boot for my 04 DHS I have to buy a set of 4 or I can buy them individually?
    Sep 2010
    East Boston MA.
    29
    26,325
    Well of the coil tested bad, you need the coil, not the boot. Normally, they're sold on sets of 4.
    Jan 2012
    san diego
    29
    414
    Ok now I'm a lil confused of what a coil is and what a boot is. The mechanic mentioned that coil #2 was no good. Again I thought he was referring to the coil/boot you remove to get to the spark plug??
    bigtone's Avatar
    bigtone is offline Cadillac Owners Enthusiast
    Automobile(s): 2010 DTS, 2006 DTS, 2001 Deville,
    Jun 2003
    545
    The boots are not replaceable by themselves on the 04-05. I had a similar miss on the 05 I used to own. Took me over a month to find it But I found that the boots on the front coil bank did not fit real tight on the plugs. I used dielectric grease on the boots, and it fixed the problem. The front coil bank did not look like the rear, I think it was aftermarket. But I would try the grease trick before I buy a coil.
  16. #14
    68
    81,941
    #2 is the coil and boot. I believe they come as one.
  17. #15
    Jan 2012
    san diego
    29
    414
    I'll have to pop the hood and look because when I changed out my plugs I didn't see anything that resembled these pics.
  18. Remove Advertisements
