Need some direction
Results 1 to 5 of 5
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Need some direction in Past Cadillac Vehicle Discussion; Hi guys I've got an 1994 Cadillac Deville with 132,000 miles and last week the gas pedal started pulsating when ...
    damondknapp is offline Cadillac Owners Member
    Jan 2013
    1
    Need some direction
    Hi guys I've got an 1994 Cadillac Deville with 132,000 miles and last week the gas pedal started pulsating when I turned off the ignition. I visually saw that the Idle Speed Control moving in and out. So I just replaced it and I still have the same problem. I'm going to go to my last resort of disconnecting the battery for a day to see if I can't manually reset the computer. But wondering what to do if that doesn't work. Please help she's been a great car for me. Been so happy with her I went out a bought a 1995 Cadillac Deville.
    Jfarr is offline Cadillac Owners Member
    Jun 2013
    65
    Re: Need some direction
    They're going to ask you if you've pulled the codes, what they are and their definitions. (^Sticky^)
    69
    82,380
    I am not sure, but I think it is just setting itself up for the next start. I remember my '92 doing that and it never gave me any problems. Unless you are having an idle problem, I wouldn't worry about it.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,847
    ALWAYS - check for Diagnostic Trouble Codes -
    if you don't know how - go here and read the ENTIRE post -
    http://www.cadillacforums.com/forums...odes-dtcs.html
    if you have any codes - post them here -
    ALONG WITH THEIR DEFINITIONS -
    I suspect a problem with the TPS - Throttle Position Sensor -
    either out of adjustment - or defective -
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,689
    The ISC needs to be adjusted once installed. It must be retracted thru on board diagnostics then a measured clearance is set by screwing in the nose switch shaft. That why you need a factory manual! The ISC should only extend just prior to start up and retract as the car is shut off.
  8. Remove Advertisements
