Results 1 to 6 of 6
Thread: power steering leak
    cadillac griff is offline Cadillac Owners Fanatic
    Automobile(s): Deville 03
    Aug 2013
    Baltimore
    177
    power steering leak
    After me n my buddy changed his high pressure hose, we realized a leak was still present when bleeding the system.. It appeared that when he turned left it would begin to drip a good amount, not so much when wheel was turned to right! The leak was coming from the middle of the car, a Lil bit in front n to the right of where the supply n return hoses hook up... Any help with where it could be, I was guessing steering gear boots but I believe there right on the inside of the tire? Thx
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,701
    Re: power steering leak
    Quote Originally Posted by cadillac griff View Post
    sounds like a seal in the rack is leaking -
    Aug 2013
    Baltimore
    177
    Does that mean the steering gear assembly would have to be replaced?? What exact part are u referring too?
    Rack in pinion???
  5. #4
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,701
    Rack in pinion???
    YES - but it isn't the steering gear -
    it is simply called the rack - as in rack and pinion steering -
    inside the "tube" is a part that looks like a ladder - this is the "rack"
    the rack gets moved back and forth by a special worm gear - the "pinion"
    hence - "rack and pinion" steering -
    the seal inside the rack is probably worn out and leaking -
  6. #5
    Caddy-EaRL's Avatar
    Caddy-EaRL is offline Cadillac Owners Enthusiast
    Automobile(s): 2000 DTS 194,000 miles, 2000 DHS 203,000 miles
    Apr 2013
    Ky
    51
    718
    According to all data, Chilton and Mitchell, the rack and pinion is the steering gear. Even on rock auto it list the rack as the steering gear. I suppose because "steering gear" is a more general term for a geared device used to steer a vehicle. And a "rack and pinion" would be a more specific way of describing that device.
  7. #6
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,701
    Quote Originally Posted by Caddy-EaRL View Post
    HEY Grandpa -
    I always thought of the steering gear -
    along with the pitman arm - idler arm - and drag link -
    as being replaced by the rack -
    but - I stand corrected -
  • You may not post replies
