Results 1 to 13 of 13
Thread: 1991 touring deville Service Code "CCR"
    satinblack91's Avatar
    satinblack91 is offline Cadillac Owners Member
    Automobile(s): 1991 touring deville
    Sep 2013
    minneapolis, mn
    24
    Hows it going fellas & Ladies....
    Loving the cadillac app, about as much as i love my cadillacs, but i could use a little help figuring out a couple problems!
    First i have a 1991 Touring Deville 4.9 & I have a code on my comp. display saying service "CCR"????? Any ideas? I dont have the money or time at the moment to get it checked out by a diagnostic...
    Another issue im having unfortunately is the Bose Gold series stereo, it turns on fine, but no sound at all... I checked all the relays behing the glove box and their fine! I was told by a friend that he had a similar problem with the cd player bose gold series aswell and it was an internal amp in the stereo! He swithched it out with a bose cassette and never had another issue! Any ideas???
    I have a 91 deville touring 4.9 with a service CCR code coming up. Does anybody know what it means? Or how to fix it??? Please help
    Last edited by Submariner409; 09-21-13 at 09:25 AM. Reason: Duplicate posts from duplicate merged threads
    orconn's Avatar
    orconn is offline Cadillac Owners 10000+ Posts
    Automobile(s): Cadillac 95 STS, 02 SLS
    Oct 2007
    Midlothian, VA
    73
    13,792
    Re: Computer code reading CCR???
    Haven't a clue, but welcome to the Forums anyway!
    Ninjobitch's Avatar
    Ninjobitch is offline Cadillac Owners Member
    Automobile(s): 1991 Sedan Deville 4.9l
    Aug 2013
    33
    81
    Quote Originally Posted by satinblack91
    Start here its out of the FSM get one of these specific CCR codes and I'm sure some one will help you I don't know squat about it, but if you let me know what code I can get you the relevant pages out of the Service Manual
  5. #4
    Sep 2013
    minneapolis, mn
    24
    Re: 1991 touring deville Service Code "CCR"
    thanks for the info my dude... i appreciate it!!!
  6. #5
    talismandave's Avatar
    talismandave is offline Cadillac Owners Master
    Automobile(s): 1980 Eldorado, 1974 Talisman, 2004 Volvo C70,
    Mar 2012
    Madison WI
    58
    7,894
    It's a fan of old 70's rock bands featuring John Fogerty?
    Hopefully a moderator will move this tomorrow to the correct area to get tech advice.
  7. #6
    Jesda's Avatar
    Jesda is offline Super Moderator
    Automobile(s): 2002 Seville STS F55, 2006 Mazda Miata
    Sep 2003
    DETROIT
    35
    22,380
    Computer Command Ride, I believe, so the error has to do with your suspension.
    As for the Bose Gold system, I put a 94 head unit in my 92 STS with Bose Gold and enjoyed improved sound. I unfortunately had to give up my tuner since the BG system uses an external tuning module, requiring an antenna extension cord that I never bothered installing.
    Not sure if your 91 Deville is the same way as my 92 STS but I imagine the connectors would be the same.
    Can't hurt to dig around the junkyard for a replacement. Corvettes, Sevilles, Devilles, and Eldorados used Delco/Bose Gold.
  8. #7
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    There is no amp in the HU, it's just a tuner/control unit. There are individual amps at each speaker. If all of the speakers stopped working at the same time, the HU is probably the problem.
  9. #8
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,681
    that is not a "CODE" - that is simply a DIC MESSAGE -
    warning you about a problem with the suspension system -
    CODES don't just appear - you must "pull" them -
    to check for Diagnostic Trouble Codes -
    if you don't know how - go here and read the ENTIRE post -
    http://www.cadillacforums.com/forums...odes-dtcs.html
    if you have any codes - post them here -
    ALONG WITH THEIR DEFINITIONS -
  10. #9
    the recluse is offline Cadillac Owners Connoisseur
    Automobile(s): 2002 STS, 1991 Eldorado
    Feb 2009
    Jacksonville, FL
    1,023
    ANY CCR code in the '91 will mean the struts or front shocks...it just means they are going bad or the electronics are going out.
    If they don't bounce or ride funny, then more than likely the salt has been getting to the electrics over the years. You can either ignore the code (if the stuts are fine), or replace the struts.
    They DO NOT make CCR shocks anymore, only passive ones. Wire in a resistor (or buy the "bolt in" resistor) to stop the codes from being thrown...
  11. #10
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,681
    Quote Originally Posted by the recluse View Post
    the resistor "trick" does NOT work on CCR systems -
    however - there IS a "trick" using a relay that DOES work -
  12. #11
    Feb 2009
    Jacksonville, FL
    1,023
    Quote Originally Posted by basscatt View Post
    You're probably right on that one...it's been a few years since I had replaced the front on my Eldorado...
    I know when I was putting them in they offered a direct in-line plug in that took the codes out of the equation.
  13. #12
    Kathyanddale is offline Cadillac Owners Member
    Automobile(s): 1991 sedan deville
    Jul 2016
    59
    I have a 1991 Cadillac Sedan DeVille I just checked my error codes I got error code 15 error code 38 error code 52 error code 71 error code 73 and error code 74 what the hell do these mean
  14. #13
    1969byrdman's Avatar
    1969byrdman is online now Cadillac Owners Connoisseur
    Automobile(s): 2003 DeVille base, 130K miles
    May 2014
    Van Zandt County, Texas
    1,710
    Quote Originally Posted by Kathyanddale View Post
    you happened to find a three year old dead thread. OBD1 codes can be found here: http://z-cut.de/US/dtcobd1.html
  • You may not post replies
