1994 Deville tail light wires crossed?
Results 1 to 4 of 4
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 1994 Deville tail light wires crossed? in Past Cadillac Vehicle Discussion; I am having trouble with my tail lights. when my turn signals are on the bulbs will light up the ...
    wpgsfinest1 is offline Cadillac Owners Member
    Automobile(s): 1994 cadillac sedan deville
    Sep 2013
    1
    Angry1994 Deville tail light wires crossed?
    I am having trouble with my tail lights. when my turn signals are on the bulbs will light up the proper filament on one bulb, but the other bulb will light up the wrong filament and they blink fast. is it possible that there are wires crossed? and when the headlights or park lights are on they seem to act normal? wtf
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,477
    Re: 1994 Deville tail light wires crossed?
    Quote Originally Posted by wpgsfinest1 View Post
    you probably have a bad ground -
    rodnok01's Avatar
    Feb 2012
    NC
    6,651
    Yep prob bad ground or a crappy corroded socket causing ground problems.
    Feb 2003
    california
    69
    6,663
    Common for a corroded socket. You are seeing feed back into another socket. Blinking fast is an indicator of a poor ground or corroded bulb. With the lights off and the 4 way flasher on, walk the car to determine which bulb is either dim or not working. Investigate that bulb and that socket. You can buy a new socket from most parts store in the HELP line of products.
  7. Remove Advertisements
