How to remove headlight switch? 1994 Deville
Results 1 to 6 of 6
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, How to remove headlight switch? 1994 Deville in Past Cadillac Vehicle Discussion; I'm troubleshooting a no headlight problem and need to check the wiring at the switch. I can't find any information ...
    steamin53 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Sep 2006
    3
    QuestionHow to remove headlight switch? 1994 Deville
    I can't find any information on how to remove the switch.
    I need someone with experience to assist by talking me through it?
    Steve
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    Feb 2004
    Minnesota
    65
    15,358
    Re: How to remove headlight switch? 1994 Deville
    Quote Originally Posted by steamin53 View Post
    Steve
    the headlight switch is RARELY the problem -
    before you rip into the dash -
    you need to check everything else out -
    under the hood you will see a couple fuse boxes -
    one is the "regular" fuse box - you will see 5 fuses for the headlights -
    check the HDLPS fuse - that one powers the relay - dimmer switch etc -
    the other 4 fuses are for the 4 various headlights -
    the other fuse box has maxi-fuses and relays -
    check the "D" relay- that is the headlights relay -
    Sep 2006
    3
    It's the switch that is the problem. The neighbor has GM service experience and got it out for me and confirmed my suspicion. Now I wonder if there is any replacement for the headlight switch and dimmer rather than the entire module.
    Steve
    xKingj's Avatar
    xKingj is offline Cadillac Owners Member
    Automobile(s): 1994 Cadillac Deville
    Aug 2014
    Houston, T.X
    26
    Where is the other fuse box located? I see the 1 labeled fuses under the hood and i know the other one in the trunk
    Quote Originally Posted by basscatt View Post
    the headlight switch is rarely the problem -
    check the hdlps fuse - that one powers the relay - dimmer switch etc -
    check the "d" relay- that is the headlights relay -
    bigm57ict's Avatar
    bigm57ict is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Coupe deVille, 1995 Sedan DeVille (sold)
    Aug 2011
    Wichita Kansas
    44
    1,845
    One fuse box under the hood, driver's side
    Other fuse box in the trunk, driver's side, panel in the sidewall
    Maxifuses are located right next to the fuses in the first box (engine). You'll have to remove the entire cover, not just the hinged access panel, to get to them.
    xKingj's Avatar
    Aug 2014
    Houston, T.X
    26
    And do any of the maxi fuses control headlights?
    My issues that i'm trying to resolve are
    1)blinking e fuel gauge
    2) fuel door/trunk button release doesn't work (and the button in the glove box is in the correct position)
    3) headlight chime wont turn off when i manually turn on the headlights
    4) twilight sentinel doesn't work
    if anything i want my gas gauge to work and the headlight chime to go away when i turn on the lights manually
    Quote Originally Posted by bigm57ict View Post
    one fuse box under the hood, driver's side
    other fuse box in the trunk, driver's side, panel in the sidewall
    maxifuses are located right next to the fuses in the first box (engine). You'll have to remove the entire cover, not just the hinged access panel, to get to them.
  9. Remove Advertisements
