replacement shocks nonnair ride
Results 1 to 7 of 7
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, replacement shocks nonnair ride in Past Cadillac Vehicle Discussion; looking for shocks to replace factory ones but I don't want air ride ...normal shocks...
    eddielnordman's Avatar
    eddielnordman is offline Cadillac Owners Member
    Automobile(s): 1995 DeVille 4.9L (with skirts)
    May 2013
    phx az its hot over here
    42
    63
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    With "normal" shocks, the rear will sag with any weight in the car. The coil springs are soft, and were never intended to work without the ELC system.
    There are shocks with "helper springs" but they're expensive, the car will have a harsher ride, the rear will still sag under heavier loads, and they can be noisy.
    Why don't you want to use ELC compatible shocks? They're really not expensive. If your compressor isn't working, I'd suggest getting ELC comparable shocks, and a manual fill kit.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,487
    Re: replacement shocks nonnair ride
    Quote Originally Posted by eddielnordman View Post
    you can't use "normal shocks" -
    Cadillac uses fairly weak rear springs -
    JUST barely strong enough to support the empty weight of the car -
    and incorporates special shocks with built in air bladders - part of the Electronic Level Control system -
    to raise the body of the car - to compensate for added weight in the back seat and/or trunk -
    that is what gives us that Cadillac ride we all expect -
    if you tried to use "regular" shocks -
    the car WILL bottom-out over every little dip in the road -
    even without anyone in the back seat - and nothing in the trunk -
    with that said - your only other choice is coil-over rear shocks -
    which would be a BIG MISTAKE -
    note the big - heavy duty coil spring wrapped around the shock -
    they ride very hard - more like a 1-ton truck than a Cadillac -
    they are noisy -
    ride-height will never be correct -
    the rear will ride too high with the back seat and trunk empty -
    and will ride too low with a loaded back seat and trunk -
    did I mention they SUCK - compared to the regular air-shocks -
    if you are still convinced this is what you want -
    the Monroe 90009 kit is the best one -
    the best price is $116.11 - with free shipping -
    http://www.justsuspension.com/monroe...kit-90009.html
    a is MUCH better solution -
    assuming your Automatic Level Control system no-longer works -
    you can install a manual fill kit - and preserve that Cadillac ride -
    if the rear shocks are shot -
    Monroe 40046 - these are the correct rear shocks for your car -
    $108.56 each - with free shipping -
    and the Monroe AK29 manual fill kit - $12.95 -
    http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER
    THIS would be the proper way to do it -
    the only difference will be you must manually inflate - or deflate the rear shocks
    as your load changes -
    if your load does NOT change often - you won't have to mess with it -
    at least you Cadillac will still ride like a Cadillac -
    Bigfoot9878 is offline Cadillac Owners Member
    Automobile(s): 1989 Cadillac Fleetwood Fwd.
    Sep 2013
    33
    4
    I installed regular struts in the back of my 89 fleetwood, and it sets about an inch lower than i'd like. And thats just with a 15" woofer and an amp in the trunk.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,487
    Quote Originally Posted by Bigfoot9878 View Post
    yep -
    you need the Monroe 71798 rear struts -
    $60.17 each - with free shipping -
    http://www.amazon.com/gp/product/B00...A1ATZ3MAARQNEF
    and if the Auto Leveling Control is not working -
    I believe the Monroe AK18 manual fill kit will work - around $10 -
    May 2013
    42
    63
    thanks all I will stick with the cadi ride.....
    Mafiaman111 is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Deville 159k
    Oct 2010
    Pennsylvania
    449
    I used those Monroe shocks for my rear and there OKAY the car rides more like a Chevy Impala then a Cadillac
  10. Remove Advertisements
