2003 deville driver side door panel
Results 1 to 4 of 4
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 2003 deville driver side door panel in Past Cadillac Vehicle Discussion; ok my drivers side window broke today, im having trouble getting the drivers side door panel off, i have the ...
    houg is offline Cadillac Owners Fanatic
    Automobile(s): 81 supporter
    Sep 2011
    newington connecticut
    56
    365
    ok my drivers side window broke today, im having trouble getting the drivers side door panel off, i have the screw out behind the handle and the lock button off, i pulled the panel loose all the way around but it seems like theres something around the arm rest area holding it, any tips on how to remove it will be a great help, i pulled it like hell but im afraid im gonna break something
    i also here that there is a cotter pin method to repair the regulator , i did a search but cant find it, any one have a link
    68
    81,748
    Re: 2003 deville driver side door panel
    DO NOT pull on it, you'll break it. Lift it off. Once it's off you'll see why.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,258
    Quote Originally Posted by houg View Post
    Deville window fix -
    go to post #38
    http://www.cadillacforums.com/forums...air-howto.html
  5. #4
    Sep 2011
    56
    365
    well i pulled it apart and epoxyed the little ball back in place, works so far
    as far as the cotter pin method it might look good in pictures but it really does not help any in my opinion, the ends of the cotter pin are too far from the ball on the wire and really do nothing
  6. Remove Advertisements
