how do i replace my waterpump pulley?
Results 1 to 8 of 8
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, how do i replace my waterpump pulley? in Past Cadillac Vehicle Discussion; I noticed my serpentine belt had slipped off the pulleys and when I tried to put it back on it ...
    ambreezyxoxo is offline Cadillac Owners Member
    Automobile(s): 1990 cadillac deville
    Sep 2013
    26
    1
    I noticed my serpentine belt had slipped off the pulleys and when I tried to put it back on it just kept on slipping off again and again. then I noticed the water pump pulley was sticking out about an inch or so from where it should be and that's why the belt wouldn't stay. I have no clue about how to work on a car at all can anyone simpley explain what I need to do to fix that pulley???
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    8,021
    Re: how do i replace my waterpump pulley?
    Off to FWD...
    bigm57ict's Avatar
    bigm57ict is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Coupe deVille, 1995 Sedan DeVille (sold)
    Aug 2011
    Wichita Kansas
    45
    1,845
    If the pulley is not aligned where it should be with the belt, you probably will need to replace the water pump.
    I had this happen recently. My belt came off and I discovered the W.P. pulley was wobbly.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,852
    Quote Originally Posted by ambreezyxoxo View Post
    you don't "fix the pulley" - you replace the water pump -
    call around and get quotes on replacing the water pump -
    choose a shop - and have the car towed there - DO NOT DRIVE THE CAR -
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,689
    Most times the pulley will be damaged so the quote should include the pulley as well and possibly another serp. belt
    Caddy-EaRL's Avatar
    Caddy-EaRL is offline Cadillac Owners Enthusiast
    Automobile(s): 2000 DTS 194,000 miles, 2000 DHS 203,000 miles
    Apr 2013
    Ky
    51
    742
    Quote Originally Posted by carnut
    Why would the pulley be damaged? I've rarely ever seen a damaged water pump pulley and I've replaced more water pumps than I could ever count lol
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,494
    The pulley should be bolted to the water pump. If it got loose you need to bolt it back on. If the water pump broke apart and that's why the pulley moved replace the water pump. If the pulley isn't damaged don't bother replacing it.
    Feb 2003
    california
    69
    6,689
    The pulley can move forward because the bolts holding it to the waterpump shaft loosen, elongating the pulley holes and in extreme cases, crack around those holes. Best thing when replacing the pulley is to use star washers under the bolts. They dig into the pulley preventing future loosening. Seen many damaged pulleys on 4100 and 4.5 engines. I mention the pulley only because this poster will not be doing the work and needs as close to a complete estimate as can be gotten the first time.
  11. Remove Advertisements
