2000 DeVille; Any way to reduce body roll or stiffen up suspension?
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 26
Like Tree1Likes
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 2000 DeVille; Any way to reduce body roll or stiffen up suspension? in Past Cadillac Vehicle Discussion; It there any way to stiffen up the suspension or reduce body roll in a 2000 DeVille? Just looking for ...
    GeoGoGo is offline Cadillac Owners Member
    Automobile(s): 2000 Deville
    Jan 2005
    Upstate NY
    46
    72
    It there any way to stiffen up the suspension or reduce body roll in a 2000 DeVille? Just looking for a less floaty ride. I have replaced the struts and shocks with Monros but that it is still floaty. It handles like a jelly donut. Are there any options to increase the handling performance of this car? Thanks for the time and have a great day everyone!
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    You could install '00-'05 DTS springs and sway bars. The shocks won't work because they're active, and your car doesn't have the electronics to support that feature.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,481
    Re: 2000 DeVille; Any way to reduce body roll or stiffen up suspension?
    you are driving a Cadillac Deville - not a go-cart -
    they are supposed to "float" down the road -
    but like MoistCabbage said -
    you could stiffen it up by replacing the front and rear springs - and sway bars -
    with the FE3 units from the 2000 to 2005 Deville DTS -
    replacing the springs is easy -
    replacing the sway bars is gonna be a bitch -
    here are the part numbers for the springs -
    Deville DTS coil springs -
    dealer only -
    front - 22197592 -
    rear 25670966 -
    purelux is offline Cadillac Owners Fanatic
    Automobile(s): 2003 deville
    May 2011
    487
    Depending on condition changing out the sway bar bushings and end-links should help some.
    68
    82,070
    Sounds like you might be happier with a DTS.
    RippyPartsDept likes this.
    Jan 2005
    Upstate NY
    46
    72
    I absolutely would but I inherited this base DeVille from my Dad and I really like not having any payments. LOL!
    68
    82,070
    Roger that. Turning a base Deville into a DTS (ride wise) is going to get expensive and labor intensive.
    Jan 2005
    Upstate NY
    46
    72
    The springs and sway bars seem to be the way to go. Does anyone have any ideas on pricing for the springs and sway bars?
    68
    82,070
    Your best bet would be to check with Chris (Rippy) over there >>>>>>>>>>>>
    He gives forum members a discount.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,481
    Quote Originally Posted by GeoGoGo View Post
    like I said - replacing the springs is cheap and easy -
    the sway bar parts aren't all that expensive either -
    but LABOR is going to be STAGGERINGLY EXPENSIVE -
    and keep in mind - it is still NOT going to handle like a go-kart -
    it WILL ride harder - and MIGHT handle a little tiny bit better -
    you will NOT be happy with the results - compared to the cost -
    Feb 2003
    california
    69
    6,663
    Get the fatter DTS sway bars from a junk yard and replace the black rubber end links with the orange or red urethane ones. The sway bars flatten out the cornering and the ride will be the same. The bars are the cheapest way to improve the handling. When I had my rear wheel drive 84 sedan, I used the bars off a Police car Caprice. Made a world of difference and still had the Cadillac ride.
    Jan 2005
    Upstate NY
    46
    72
    Is there a write up anywhere for the sway bar install? What exactly makes it so labor intensive?
    Quote Originally Posted by carnut View Post
    I did the same on my 95 Fleetwood! I installed the 9C1 (police Caprice) springs and sway bars along with HD Bilstien shocks all around. That car was so much fun. I miss it so much!
    68
    82,070
    I doubt it, but if there is it will be in the Tech Tips section.
  16. #14
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,481
    drop the exhaust -
    drop the rear suspension cradle -
    and for the front -
    lower the engine cradle -
  17. #15
    Faith76's Avatar
    Faith76 is offline Cadillac Owners Enthusiast
    Automobile(s): 89 Sedan DeVille, 90 Fleetwood, 94 Fleetwood Hearse
    Jul 2013
    Fredonia, NY
    41
    557
    I kind of feel the same way about my Deville. I've been told spring stiffeners might help, but then I was told spring stiffeners are damaging. I guess I just need to adapt. Let me know if anything works for you!
  18. Remove Advertisements
