Monroe Shocks
Results 1 to 9 of 9
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Monroe Shocks in Past Cadillac Vehicle Discussion; 03 deville...Im having trouble finding a shock (ma822) that has a srew on air hose connector. Is there and adapter ...
    Deville4life is offline Cadillac Owners Member
    Automobile(s): 2003 Deville
    Sep 2013
    29
    8
    Monroe Shocks
    03 deville...Im having trouble finding a shock (ma822) that has a srew on air hose connector. Is there and adapter i can use?
    68
    82,062
    Re: P/S high pressure hose help - 2003 Deville
    The MA822 is a direct fit (plug n play) replacement. I don't think any adapters are available with a screw fitting. Why do you need/want a screw on fitting?
    P.S.
    Don't hijack someone elses thread. I moved this to your own thread.
    purelux is offline Cadillac Owners Fanatic
    Automobile(s): 2003 deville
    May 2011
    487
    Doesn't the Gabriel hi-jacker use screw on fittings.
    Sep 2013
    29
    8
    my air hose is a srew on
    P/s sory about your thread im new to this site..
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,476
    Re: Monroe Shocks
    Quote Originally Posted by Deville4life View Post
    If I understand this correctly -
    you have the Monroe MA822 rear shocks -
    but the car air lines have been modified to the screw cap
    rather than the stock plug-in -
    if this is correct - you have THREE choices -
    get a new airline set from the dealer - $$$$$$$$$ -
    hit the junk yards for a good used air line set -
    get the Monroe AK29 manual-fill kit - less than $15 -
    it has the correct "factory" plug on the shock-end of the air line -
    you just have to look at what was changed - and change it back -
    Sep 2013
    29
    8
    Re: Monroe Shocks
    Thanks alot i got it
    68
    82,062
    Re: Monroe Shocks
    I don't think you have Monroe MA822's on there. I just installed 2 sets and they have factory snap on connectors. If yours are screw on, they are either not MA822's or not Monroe.
    Sep 2013
    29
    8
    Re: Monroe Shocks
    yes its AC delco but it a screw on. MA822 is the cheaper one i could find but the dont have a screw on version
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,476
    Re: Monroe Shocks
    sounds like someone put on the FAKE ACDelco Gabriel hi-jackers -
    a real crappy shock compared to the Monroe ma822 -
  12. Remove Advertisements
