2001 DTS Front Brake Job Question
Results 1 to 2 of 2
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 2001 DTS Front Brake Job Question in Past Cadillac Vehicle Discussion; I am about to do a front brake job on my 2001 DTS and had a question regarding this process. ...
    sgillis is offline Cadillac Owners Member
    Oct 2003
    7
    Talking2001 DTS Front Brake Job Question
    I am about to do a front brake job on my 2001 DTS and had a question regarding this process. First, does the DTS require the standard or heavy duty rotors and pads? Second, are the rotors "pressed on", which would require a specialized tool to remove? Thanks!
    Scott
    Katshot's Avatar
    Katshot is offline Cadillac Owners Master
    Jan 2003
    Newtown, PA
    58
    6,472
    Re: 2001 DTS Front Brake Job Question
    Welcome aboard,
    The DTS uses standard parts and the discs will just pop off. No pressing required. There will most likely be a couple copper-colored retainers on the lug bolts that you'll have to break off but that's ok. They're only there for production, no need to worry about replacing them or anything.
