Help- 1999 Concours
Results 1 to 4 of 4
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Help- 1999 Concours in Past Cadillac Vehicle Discussion; 1999 Deville concourse Cam wore 2 lobes/lifters on rear exhaust cam, changed cam and oil pump. I checked engine light ...
    ffemt702 is offline Cadillac Owners Member
    Automobile(s): 1999 Deville Concours
    Nov 2012
    32
    Help- 1999 Concours
    Cam wore 2 lobes/lifters on rear exhaust cam, changed cam and oil pump. I checked engine light since replaced cam sprocket with original, light went out. Now deville is running hot with the following codes.
    P1376
    P1258
    P0307 on #7, I changed the #7 plug again. all plugs are new anyway with AC Platium plugs
    B1255 or B1Z55
    The car will heat up and almost get to 3/4 quarters on temp guage, I changed the thermo stat- made no difference. The line on top of res. has anti freeze coming out. Could it be waterpump?
    68
    81,755
    Re: Help- 1999 Concourse
    Codes are meaningless without definitions.
    If the belt is on and spinning, it's not the WP. Are you sure that the ECT sensor is connected?
    Nov 2012
    32
    Disconnected battery and all codes have cleared. had a little surge at idle, changed plugs and wires, all good now. Might change the drive belt, seems to slip a little. Caddy seems to run a little hot, temp guage is in middle and low coolant light comes on. Hopefully not a head gasket now. I changed the thermostat, still no difference in temp. What should I do? Get antifreeze tested for hydrocarbons? change water pump?Put some of that 24 hour sealant stuff in the engine?
  5. #4
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,566
    What is the temperature of "little hot" ? The engine is supposed to run between 190 and 215 - that's the dead area right at 12 o'clock on our "gauge".
    Check temps with an IR gun from Radio Shack.
    The correct thermostat is set to begin opening at 188 and fully open at 206. Fans go to SLOW at 224 or whenever any HVAC function calls for A/C compressor operation.
    Gauge ??? Find the annotated picture in my albums - Click my username, open the profile. Left column, 'albums'. 2 albums, 6 pages of diagrams and pictures, most for 2000 and later, but many apply to your engine.
    DO NOT dump any sealant goop into the cooling system. Find the leak and repair it. If the low coolant message displays, is the level at the proper half-full line in the surge tank with the engine cold ?? (Never check/adjust coolant levels with the engine warm and/or running.)
  6. Remove Advertisements
