1997 Deville - fuel level readings erratic
Results 1 to 8 of 8
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 1997 Deville - fuel level readings erratic in Past Cadillac Vehicle Discussion; Just joined this forum and i'm glad I stumbled upon it. I have a question I just bout a 97 ...
    caddydaddy24 is offline Cadillac Owners Member
    Automobile(s): 1997 Cadillac Deville
    Aug 2013
    28
    3
    Just joined this forum and i'm glad I stumbled upon it. I have a question I just bout a 97 deville and it has a faulty fuel level reading. Its all over the place. How can I fix that.
    dqao is offline Cadillac Owners Member
    Automobile(s): 2002 Cadillac Deville DTS
    Mar 2008
    24
    I had a similar problem on my 2002 Deville and I replaced the fuel sending unit on the fuel pump and the problem was solved. Not sure if that will work with your model but I'm sure someone will confirm that.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,919
    Re: what's up guys!
    Fuel level sender. Drop the tank, remove the pump module and either replace the level sender - or the entire pump unit. The pumps also have a very finite lifespan.
    Let's move this up to the Deville forum for more fuel system advice. Off we go.
    Study the entire Cadillac Techical Archive way up ^^^ in the black bar, then page through Discussions, Cadillac Tech Tips for threads of interest - including lots of advice on your fuel level problems.
    Aug 2013
    28
    3
    Re: 1997 Deville - fuel level readings erratic
    Thank you very much. If it is the sending unit should I just replace the pump while I'm at it?
    70cougar is offline Cadillac Owners Enthusiast
    Automobile(s): 2002 DTS, 70 Cougar conv
    Dec 2009
    Connecticut
    725
    Quote Originally Posted by caddydaddy24 View Post
    Probably yes. Do you know how many miles are on the pump? If it's original, it's definitely living on borrowed time.
    68
    81,928
    Check Rockauto. You can get the entire unit for less than the sender alone, depending on the brand of coarse.
    Aug 2013
    28
    3
    I want to say it is the original pump. And im currently at 119xxx on the miles. And also im going to chwck rockauto. Thanx
    Feb 2006
    55,919
    Airtex #3935M module. Probably an original DELPHI/UltraPower unit.
  11. Remove Advertisements
