service engine light
Results 1 to 3 of 3
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, service engine light in Past Cadillac Vehicle Discussion; Service engine light comes on after car has been idling for approx. 5 minutes. system was reset and when I ...
    Leon j. harris is offline Cadillac Owners Member
    Automobile(s): deville dhs
    Aug 2013
    Service engine light comes on after car has been idling for approx. 5 minutes. system was reset and when I came home and set in the drive way for about 5 minutes light came back on
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,127
    Re: service engine light
    What year is your DHS - it makes quite a difference in how we advise you to start diagnosis, but .......
    Use the sticky post, just above this thread, titled "How to pull codes" - Diagnostic Trouble Codes - from your car's built-in code reader/scanner/memory. Use the appropriate year group and pushbutton sequence to turn your DIC into a DTC readout, write down all found codes and whether each is Current or History - then return to the sticky to open the link to the correct year lists of code definitions. Decipher all your codes and post it all here.
    ?? DIC ?? DTC ?? - Study the sticky post ^^^ Acronyms. (Get the idea that ALL stickys are important background info ???)
    Update your profile to look sort of like other members login headers - the info sure helps. The Settings tab ^^^, edit profile.
    69
    82,382
    and
