Need help identifying a connector for a 97 Deville Concours. In the engine bay.
Results 1 to 11 of 11
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Need help identifying a connector for a 97 Deville Concours. In the engine bay. in Past Cadillac Vehicle Discussion; As seen in this picture what is the blue shrouded connector for. There is two exiting the loom at about ...
    jeepflambe is offline Cadillac Owners Member
    Automobile(s): 97 Deville Concours 1G6KF5496VU281009
    Jul 2011
    Miramichi NB Canada
    53
    31
    There is two exiting the loom at about the same spot. One is connected to a plug in the cylinder head but I do not know where this one goes. I may be tearing this thing apart again as I cannot seem to isolate where this one connects to.
    I am on the cusp of completely finishing a water pump crossover gasket replacement and now this. I suspected it attached to the intake manifold or throttle budy but I cannot find a receptacle for it.
    Its hot here and my brain is heat addled any help is always appreciated.
    69
    82,383
    Re: Need help identifying a connector for a 97 Deville Concours. In the engine bay.
    Can you open the picture up a bit? What's it connected to on the right side?
    Jul 2011
    Miramichi NB Canada
    53
    31
    Its just hanging loose. It is not currently connected to anything.
    Its such a bugger to see into that part of the engine bay. I cannot recall seeing any connector receptacle other than those for the block heater and another one in the rear bank cylinder head.
    69
    82,383
    OK, now I see. I thought it was plugged into the gray tube or cable at the far right. I checked my '03, but didn't see any connector that color though I wasn't really sure where I was looking from such a close up. Maybe someone with a '97 will have better luck.
    Jul 2011
    Miramichi NB Canada
    53
    31
    Thanks Ranger
    rodnok01's Avatar
    rodnok01 is online now Cadillac Owners Master
    Feb 2012
    NC
    6,719
    I looked at my 97 and the only two wire in that area was the TPS, frt side of TB.
    Jul 2011
    Miramichi NB Canada
    53
    31
    Thanks Rodnok01 Thats something I did not check. Hard for me to see dark colours.
    69
    82,383
    I think if your TPS was disconnected you'd know it.
    Have you checked the DTC's?
    Jul 2011
    Miramichi NB Canada
    53
    31
    I checked the codes and there is a lot of them due mostly I think due to all the sensors being disconnected around the intake manifold.
    I removed my linkage and the gear position switch in order to feel about in the area behind the and around the steering input shaft. ANd nothing can be felt moreover I should have had to unhook this connector pro-actively as I doubt I could have pulled the thing off without really trying to.
    Current codes are:
    PCM
    0204
    0205
    0206
    0207
    0208
    0405
    1122
    ACM
    B1749
    TCS
    C1241
    1738
    I am feeling ill over this. I found some pics from http://www.cadillacforums.com/forums...e-leak-33.html
    The best I have found from this rebuild thread is:
    And it looks as though the connector the the input shaft for the steering but I cannot feel and certainly cannot locate the receptacle.
    Jul 2011
    Miramichi NB Canada
    53
    31
    Golly gee gosh!
    I found the receptacle
    It is for the steering
    I can barely touch it from the top side of the car. I think this needs the motor dropped good heavens what a day.
    I can touch it and I can snake the connector up to it but I need to push both bits together and cannot think of a way to do this. I was thinking maybe if I lassoed the receptacle in some way I could maybe pull on it while pushing the connector in.
    OK the lasso thing works sort of OK for the receptacle side but I cannot reach in far enough to finish the deed with the connector.
    A hot glue gun and a long stick maybe?
    Jul 2011
    Miramichi NB Canada
    53
    31
    Well homo habilis lives and breathes! I used a lassos to capture the receptacle then managed to force one arm to reach it
    I then used a fork I made from a copper pipe to deliver the connector home.
    I had to cut off the clip unfortunately it was the only way as my lasso was in the way.
    It buttoned back up to the intake manifold now. I need to buy some hose clamps and then I should be able to start the old girl after two years sitting.
    If nothing she will make a fitting end in a demolition derby hammering lesser cars into oblivion.
  14. Remove Advertisements
