Neutral safety switch
Results 1 to 5 of 5
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Neutral safety switch in Past Cadillac Vehicle Discussion; Where is the location of the neutral safety switch for the 2001 deville, I need to replace it? Also, if ...
    JohnDell is offline Cadillac Owners Member
    Aug 2013
    7
    Where is the location of the neutral safety switch for the 2001 deville, I need to replace it? Also, if you can provide a diagram, that would be great.
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    50
    1,948
    Re: Neutral safety switch
    Inside the trans pan. Called IMS (internal mode switch).
    #942
    Could just be a broken clip.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,155
    Look in my albums - there's a diagram of the 4T80E and all its internal sensors and switches. Click my username, open the profile. left column, 2 albums, 6 pages of Northstar stuff.
    While you're in there, do some research on the new model pair of 1-2 and 2-3 shift solenoids. Worthwhile maintenance.
    Talk to Chris in parts at Rippy Cadillac tomorrow morning. Over there >>>>>
    (ooooppppssss......... AZTEC beat me to it.) but my diagram has each numbered item described
    Feb 2012
    NYC
    50
    1,948
    Quote Originally Posted by Submariner409 View Post
    Yes, see if there is a metal bracket holding in the plastic screen between the 2 shift solenoids(#909). If there is, there should be no need to change them.
    69
    82,386
    Being an '01 I'm sure he has the support bracket. It was the early '90's models that had shift solenoids fail for lack of it. The replacements came with it and later it was added to the transmissions at the factory, but I don't know exactly when that was. If I had to guess, I'd say '95 or '96.
  8. Remove Advertisements
