Snapped rear caliper bolt
Results 1 to 12 of 12
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Snapped rear caliper bolt in Past Cadillac Vehicle Discussion; Hello again, to all you very informative and helpful people! Just got "done" installing new Durastop rotors and pads, but ...
    pauldimler93 is offline Cadillac Owners Member
    Automobile(s): 2002 Cadilac Deville
    Jun 2013
    23
    52
    Hello again, to all you very informative and helpful people! Just got "done" installing new Durastop rotors and pads, but on my last bolt I went to go torque down the (top rear driver side caliper bolt and It didn't make it to the full 94 ft/lbs). Now to my questions, Is it safe to drive like this for the time being? and where would I find another one of these bad boy bolts?
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,706
    Re: Snapped rear caliper bolt
    Quote Originally Posted by pauldimler93 View Post
    that's a joke - or a trick question - RIGHT?
    if you are serious - NO - it is NOT safe to drive like that -
    boneyard or dealer -
    rodnok01's Avatar
    rodnok01 is online now Cadillac Owners Master
    Feb 2012
    NC
    6,703
    Do not drive until fixed.
    Jun 2013
    23
    52
    I only asked since I live 3 miles from a caddy dealer to get the part and go, otherwise it will be a pain trying to catch a ride there and back on top of getting too and from work
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Have a bicycle?
    Ian-STS99 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Deville Limited Edition
    Dec 2008
    225
    Do NOT drive the car until the broken bolt is removed and a NEW bolt is put in place. Far too early to put one's self in a wooden box six feet under, or anyone else.
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,607
    94 pounds on those little caliper bolts? That cannot be right. Those are far too small for that. That sounds more reasonable for the bigger bracket-to-knuckle bolts. Almost 100 pounds on any little 12-13mm bolt will surely strip or snap something
    Jun 2013
    23
    52
    Have a bicycle?
    I wish I never scrapped that POS now lol.
    Quote Originally Posted by Ian-STS99 View Post
    I agree.
    Quote Originally Posted by drewsdeville View Post
    It is a 15mm bolt, the threads are almost 1/2 in diameter, I believe its even the same as the front caliper bolt. Also got the information from Alldatadiy, I am assuming they are correct on the spec's.
    Oct 2004
    Oak Creek, WI
    5,607
    ok, well I stand corrected. Typically, those are smaller dia and well under 50lbs.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,884
    Front and rear caliper specs. 2002 Seville/Deville
    Bolts - either RockAuto, NAPA, or Chris in parts at Rippy Cadillac over there >>>
    Jun 2013
    23
    52
    What a morning! Got dropped off an hour before the dealer opened, finally got the "last" bolt they had for $8 then another $35 for a taxi to work. $43 for a bolt 0.0. Anyways it is cheaper than what could have happened If I didn't ask this community first. Thanks all
    c_d
    c_d is offline Cadillac Owners Fanatic
    Automobile(s): 06 Beetle 2.5L Manual, 08 Audi A3 TDI, 04 DeVille DTS
    Feb 2012
    SAT, BER
    152
    Check your bleeder screws when you're back at the car anyway. They are made from a softer metal and can be squished due to being partially hollow. I had one in the back being totally disintegrated just under the little plastic cap. Pretty hard to spot from the outside but I did cost me driving with mushy brakes for a couple of days, a complete bleeding procedure, and a complete brake fluid change in addition to the $1.49 of the screw itself.
  15. Remove Advertisements
