Stop Engine temp light
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By Aztec ETC ECS
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Stop Engine temp light in Past Cadillac Vehicle Discussion; 1993 Deville - stop engine temp light stays on while cruising, but flashes off when accelerating or braking.... have flushed ...
    Russelllyn is offline Cadillac Owners Member
    Automobile(s): Deville
    Aug 2013
    60
    1
    1993 Deville - stop engine temp light stays on while cruising, but flashes off when accelerating or braking.... have flushed coolant system, changed thermostat and repaired head gasket leak with Steel Seal . heat and air no longer work. desperate to keep this going until next June... only 155K miles.... inherited from parents.
    can you tell me what else I can possible try?
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    49
    1,948
    Re: Stop Engine temp light
    Brace yourself for a serious hammering.
    basscatt likes this.
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,449
    First make sure it's really overheating. Does the cooling system leak? Is the rad cap good? Is the thermostat the right one? If it has a bad headgasket you'll be wasting money at the overheating problem for nothing. Get that fixed before doing anything else. Continuing to drive can only make things worse.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,487
    Quote Originally Posted by Russelllyn View Post
    you DID NOT repair anything with that - shi - ah - stuff -
    in fact - you probably caused more problems with it -
    OK - WHAT doesn't work -
    the blower doesn't blow? -
    WHAT?
    throwing parts at it - and dumping SNAKE-OIL in it -
    is NOT going to FIX anything -
    you need to properly DIAGNOSE the problem -
    THEN you can REPAIR it -
    68
    82,081
    A 4.9 with bad HG's? That's not very common.
    Feb 2012
    NYC
    49
    1,948
    ^ And is a MUCH easier repair than an N*.
    limo1's Avatar
    limo1 is offline Cadillac Owners Fanatic
    Automobile(s): 1985 Fleetwood 75
    Jul 2012
    281
    Sounds like the high temp switch screwed into the block drain hole if temp gets very high it closes and grounds the wire .
    as you are saying it only comes on during acceleration and braking it sounds like this sensor wire is touching ground somewhere and the flexing
    of the motor is breaking the grounded wire. find the wire to the sensor and make sure it is not shorting to ground.
    Last check the lamp test during the key start sequence is the ignition switch causing a short to ground flaky switch.
  10. Remove Advertisements
