1987 Deville inside AC fan / blower motor issues.
Results 1 to 2 of 2
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 1987 Deville inside AC fan / blower motor issues. in Past Cadillac Vehicle Discussion; Problem started when I turned AC off and the blower fan started and continued to blow air (not AC) even ...
    rosetone is offline Cadillac Owners Member
    Automobile(s): 1987 DeVille
    Sep 2012
    1
    Problem started when I turned AC off and the blower fan started and continued to blow air (not AC) even after I turned the ignition off. After I tried opening & closing the door, I started the car up again and the blower stopped. I went on to work. When I was going home I turned on the AC. I could feel it cooling, but the fan never came on.
    I have looked at the fuses on the drivers side. I also pulled the panel off on the passenger side to see if I could find the blower control module, and found the fuses located there. None look obviously blown.
    Does this sound like the blower control module?
    68
    82,070
    Re: 1987 Deville inside AC fan / blower motor issues.
    Either the blower itself or the resistor module (I think the '87's still used those).
