1997 Deville Passanger Side Door won't unlock?
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By amunderdog
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 1997 Deville Passanger Side Door won't unlock? in Past Cadillac Vehicle Discussion; So I get in my car today and I'm dropping off my brother and he can't get in? I unlocked ...
    Mrjshua is offline Cadillac Owners Member
    Automobile(s): 1997 Cadillac Deville
    Oct 2011
    21
    So I get in my car today and I'm dropping off my brother and he can't get in? I unlocked it with the power locks, I tried to open it from the inside and even tried using the key in the door and It still wouldn't open?
    I did a search and someone mentioned something about a Rod? Is there a way I can pop off the panel and do it myself and If so what exactly am I looking for?
    " I'd greatly appreciate anyone able to go in detail to make it easier for me "
    - Thanks for your time
    68
    82,063
    Re: 1997 Cadillac Deville Passanger Side Door won't unlock?
    It does sound like a linkage (rod) disconnect problem. You will have to remove the inner door panel to inspect it.
    Oct 2011
    21
    Is it possible to run me through on how to fix it and what I'm exactly looking for?
    amunderdog is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 SLS x 2 ---- 1993 Eldorado Sport ----- 1994 Deville 4.9
    Feb 2010
    Sunbright, TN
    1,530
    Re: 1997 Deville Passanger Side Door won't unlock?
    I guess this is one way to rectify the problem.
    http://youtu.be/QoG4hKyp1vI
    basscatt likes this.
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,449
    You're looking for a loose rod going to the door latch inside the door. It's strange that nothing works because I thought all the rods went to the latch seperately.
    Chzyrider is offline Cadillac Owners Member
    Automobile(s): 1990 Sedan Deville, '07 DTS
    Jun 2010
    Salem, Or.
    55
    15
    A similar problem happened on our '90 Deville driver's door. It was sticky and a springed lever would not raise completely to allow the locking mechanism to "flop over" to unlock allowing the release lever to work. What I did was to use a 'slim-jim' tool with the window down reaching in from between the weatherstips to catch the lever (blue clip) on the door latch (inside the door) to emulate turning the key or pressing the thumb button switch for the lock solenoid.
    Once you press/pull that lever accordingly, the door should open with the normal outer thumb button or inside lever. Studying the layout of your particular latch will help in determining which lever and where it's at. Remove the panel of the opposing door to see how it works and find which lever you need to get at on the bad door.
    The spring on ours had broken and I was able to use a spring from a ball point click-pen to wrap around the post and give it that extra boost to raise the locking lever high enough to release when unlocking. That worked for a few months, then I just finally replaced it with a junkyard one. I'm modifying the original with a bolt & new spring to repair it as a spare.
    68
    82,063
    Quote Originally Posted by Mrjshua View Post
    Not from memory. It's been about 7 years since I've had my '97. A FSM would be invaluable.
  10. Remove Advertisements
