Additional cooling fans??? - Page 2
Results 16 to 30 of 39
Like Tree22Likes
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Additional cooling fans??? in Past Cadillac Vehicle Discussion; Forget that idea. If the WP was rusted up and not turning (highly unlikely) the belt would be squealing like ...
  1. #16
    68
    82,072
    Re: Additional cooling fans???
    Forget that idea. If the WP was rusted up and not turning (highly unlikely) the belt would be squealing like a scalded cat. If the WP belt is turning, the pump is good and doing it's job. Your problem is that you are pumping (hot) gases into a system that requires liquid.
    SUPER LAC DEVILLE likes this.
  2. #17
    rodnok01's Avatar
    Feb 2012
    NC
    6,653
    Yea Lac no room and you would be better off checking antifreeze/coolant for proper mixture.
  3. #18
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    He's running straight water. Coolant is way too expensive for the amount he's burning.
  5. #19
    SUPER LAC DEVILLE's Avatar
    SUPER LAC DEVILLE is offline Cadillac Owners Enthusiast
    Automobile(s): 1998 Cadillac Deville
    Aug 2012
    Tampa Florida
    38
    854
    Quote Originally Posted by rodnok01 View Post
    can't afford 2gallons coolant a day, thats why im running distilled water
  6. #20
    rodnok01's Avatar
    Feb 2012
    NC
    6,653
    Quote Originally Posted by SUPER LAC DEVILLE View Post
    You're screwed.... you're lucky it's running that cool.
  7. #21
    dusty256 is offline Cadillac Owners Fanatic
    Automobile(s): 1996 sedan deville
    Feb 2013
    62
    188
    Even in texas with 105 days and running the ac on max the warmest my caddie ever gets at prolong stops lights is 208. And that is stock fans.
    I think everyone is right and its time to replace that hg or park it before you really mess things up.
    239 wow ..
  8. #22
    Aug 2012
    Tampa Florida
    38
    854
    Quote Originally Posted by dusty256 View Post
    239 wow ..
    try 265 a couple times... thats when Camel Mode kicks in
  9. #23
    JDemoney is offline Cadillac Owners Member
    Automobile(s): 2002 DeVille
    Aug 2013
    Box Elder, SD
    88
    You're gonna end up burning up your piston rings all to hell. Have fun.
  10. #24
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,873
    The fail runs deep in this thread
    dusty256 and BlackInjun like this.
  11. #25
    Aug 2012
    Tampa Florida
    38
    854
    Quote Originally Posted by JDemoney View Post
    Quote Originally Posted by vincentm View Post
    Yea, pretty obvious when one is dealing with failing HG's...
    "well, u should get that repaired properly, superlac"
    "Oh man, don't know why i NEVER thought of that... I Sure could use that $3,000 donation"
  12. #26
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,449
    Running it that long with just water and those high temps you might as well just keep driving it the way it is till she blows and get a used engine dropped in.
  13. #27
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,253
    Engine coolant temperature has exactly nothing to do with "burning up piston rings".
    SUPER LAC, If no other Seville/Deville/Eldorado needs 4 cooling fans and constant fan operation, why does yours ?? If the engine is overheating due to head gasket failure the ONLY way to stop that heating is to repair the engine. If it is overheating due to cooling system flow or mechanical problems, the ONLY way to fix that is to repair the problem(s).
    Throwing fans at it will NOT cure the overheating problems.
    Back in other threads of your problems with this car - didn't ypu dump in some sort of "stop leak" or other goop ? If you did, due to the nature of the Northstar cooling system, there's a very good chance that many small coolant passages/holes are now clogged up, contributing to the overheating. You don't need more fans at a stop light - you need to repair the car.
    Two 10" pusher fans, brackets, wiring, remote switching and proper installation would cost at least $200+. better to fix the basic problem.
  14. #28
    Aug 2013
    Box Elder, SD
    88
    Quote Originally Posted by Submariner409 View Post
    You know exactly what I meant.
  15. #29
    Aug 2012
    Tampa Florida
    38
    854
    Yea
    I know the Blue Devil was a mistake
    Guess all I can do is pray for it to hold out 8 to 10months
  16. #30
    Feb 2013
    62
    188
    Wow its sad you are trashing a nice caddie like that. Eight months is a long time to drive it like that . Sorry but I can see no reason to keep that car on the road untill you get it fixed. I know money is tight but a simple repair even though costly would be cheaper than what's in store once you seize that engine up for good.
    When it leaves you on the side of the road are you just going junk her out...I would find I cheap junk car to get by with untill you can give that caddie the care it needs and deserves
    Yea
  17. Remove Advertisements
