94 Deville 4.9 Coolant Leak
Results 1 to 6 of 6
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 94 Deville 4.9 Coolant Leak in Past Cadillac Vehicle Discussion; Cannot detect where coolant leak is coming from. The engine can be hot or cold, but, if I start the ...
    pooneee is offline Cadillac Owners Member
    Automobile(s): 94 sedan deville
    Aug 2009
    49
    17
    Cannot detect where coolant leak is coming from. The engine can be hot or cold, but, if I start the engine or just squeeze the top hose, a steady stream of coolant comes from the center back of the engine slightly to the driver's side dripping off of the transmission pan.
    It doesnt appear to be the water pump or any hoses.
    Anyone have an ideas?
    I now see that it is coming from the back of the engine just inside of where the oil filter is screwed in but, well below where the T-stat is.
    Is that the coolant crossover or is that a gasket for the oil filter adapter/t-stat housing?
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,682
    Re: 94 Deville 4.9 Coolant Leak
    Quote Originally Posted by pooneee View Post
    no coolant crossover on a 4.9 motor -
    it's probably the steel heater lines that have rusted out -
    there was a write-up either in Tech Tips - or the 4.9 engine forum -
    how to replace them using heater hose - new steel lines are no available -
    69
    82,262
    I don't think the 4.9 had those steel coolant lines like the 4.6?
    Here's the 4.9 heater hose diagram. If it is coming from behind the engine I would suspect #9 or 10.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,682
    I could be wrong - but I think #5 and #7 are steel -
    #9 and #10 are heater core supply and return hoses -
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,476
    Yes, part 5 and 7 in that picture are steel lines but they usually rust by the pulley. The rest of the parts are hoses. Up at the top it's usually that heater T part that goes.
    69
    82,262
    In post #1 he said "I now see that it is coming from the back of the engine just inside of where the oil filter is screwed in but, well below where the T-stat is." That would lead me to look somewhere in the vicinity of #2.
  9. Remove Advertisements
