04 DHS Heated Steering
Results 1 to 6 of 6
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 04 DHS Heated Steering in Past Cadillac Vehicle Discussion; Howdy all, I haven't posted much of anything on here since I sold my 99 STS a couple years ago. ...
    brougham96 is offline Cadillac Owners Fanatic
    Automobile(s): 1973 Sedan deVille, 2004 White Diamond deVille DHS
    Mar 2010
    St. Paul, MN
    122
    Question04 DHS Heated Steering
    Howdy all,
    Over the weekend I purchased a almost mint condition 04 Pearl White DHS. I'm already in love with this thing. As far as I can tell, every single feature works on it including the heated and cooled seats... Except for the heated steering wheel. When I press the button on the steering wheel I get no LED on the button and no heat. Checked the heated steering wheel fuse and it is fine. I'm not pulling any DTCs. What would be the next thing to check?
    -Ryan
    Sep 2003
    Metro ATL
    4,854
    Re: 04 DHS Heated Steering
    Quote Originally Posted by brougham96 View Post
    ....Except for the heated steering wheel. When I press the button on the steering wheel I get no LED on the button and no heat. Checked the heated steering wheel fuse and it is fine. I'm not pulling any DTCs. What would be the next thing to check?
    Borrow a relay from another circuit. If that makes no difference, you are digging deep inside the steering wheel/column.
    Mar 2010
    St. Paul, MN
    122
    Ah, didn't even think about the relay. I'll give that a swap when I get home. I also see a temperature sensor in that schematic. Could it be that it's just simply too hot in the middle of August for it to kick on?
    Sep 2003
    Metro ATL
    4,854
    ....I also see a temperature sensor in that schematic. Could it be that it's just simply too hot in the middle of August for it to kick on?
    Possibly. IF your steering wheel (car interior) temperature is much above 100 F why would you even want the steering wheel heated? I know, I know; just to check if it works.
    Mar 2010
    St. Paul, MN
    122
    So, fuse is okay, relay is okay. How difficult is the module to get at in the column?
    At one point yesterday I pressed the button and the LED came on for a fraction of a second and then went out,and would not come on again.
    Also just wanted to verify that the heated steering wheel should function with about a 70 degree interior.
    Again, just trying to troubleshoot it now before the Minnesota winter.
    Sep 2003
    Metro ATL
    4,854
    This from the 2004 Deville Service Manual.
  9. Remove Advertisements
